OP
dim_bulb
You crack me up biff
Discuss Switch spur behind fridge what can you do in the Electrical Forum area at ElectriciansForums.net
put the socket in the cupboard next to the fridge and cut a hole big enough for the plug to go through - this will get past the problem with a deeper fridge than normal and complies.
With this you may not need an isolation above the worktop as it can be easily isolated from the cupboard. - personally I would still put an isolation above
In the OP it states that are not any cupboards next to the fridge
Reply to Switch spur behind fridge what can you do in the Electrical Forum area at ElectriciansForums.net
