Discuss The consumer Units for flats in communal area in the UK Electrical Forum area at ElectriciansForums.net
My daughter has ground floor flat, there are four flats on each floor. The consumer Units for each flat are located just outside each flat in the communal hall way, Is this against the Regulations?
In a word no
my first house had its consumer unit in the bin store outside
you literally had to go outside to reset a breaker
This is a block of flats.... theyre not going outside in the elements to reset a breaker.... just walking out the front door into the communal area.
No worse than crawling about under a staircase.
Not checked whether its against any actual regs though.
It may not be ...but it should be.
No way should anyone be able to isolate someone else's power without entering the premises, unless it's fed from a locked 'switch room'.
Thinking, it may be illegal and nothing to do with Regs.
Plastic meter cupboard outside a house ? Anyone could walk up and pull the main fuse or switch off the main isolater switch
The Main fuse should be sealed, as if locked. As regards Isolator in outside cupboard, bad idea. I know there are plenty done like this but it's silly. They should be inside local to CU.
Every single Dno installed main isolater switch that I have seen is installed in the outdoors meter cupboard
Reply to The consumer Units for flats in communal area in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, Got a job converting commercial property into 4 flats, 2 up 2 down all with electric meters on the outside on ground floor, SWA to...
Im starting a re-wire of a top floor flat, they have run an 16mm T&E with a 6mm earth from the ground floor to the 3rd floor feeding the CU...
Afternoon All, Just pricing up a job and thought I'd pick your brains. Quick run-down, Block of Flats with an underground car park. In the...
Hi all Called to do an EICR on a property 4 studio flats / bedsits within a single house. The t&e sub main to each flat runs within the fabric of...
Hi all… just after some independent opinions… I have a VM install with 4 units in one building. The VM the engineer ran one cable from the street...
