C
chris woolf
My daughter has ground floor flat, there are four flats on each floor. The consumer Units for each flat are located just outside each flat in the communal hall way, Is this against the Regulations?
All indoors, need to know if its against the regs though!This is a block of flats.... theyre not going outside in the elements to reset a breaker.... just walking out the front door into the communal area.
No worse than crawling about under a staircase.
Not checked whether its against any actual regs though.
It may not be ...but it should be.
No way should anyone be able to isolate someone else's power without entering the premises, unless it's fed from a locked 'switch room'.
Thinking, it may be illegal and nothing to do with Regs.
The Main fuse should be sealed, as if locked. As regards Isolator in outside cupboard, bad idea. I know there are plenty done like this but it's silly. They should be inside local to CU.Plastic meter cupboard outside a house ? Anyone could walk up and pull the main fuse or switch off the main isolater switch
Not sure about being illegal as this was installed when the flats were built in the 80's and every flat in the block is in the same situation. As far as im aware the regs say it needs to be accessible, which it is, however I need to know whether it funky complies with the 18th edition of the regs, if not on what grounds?It may not be ...but it should be.
ThanksIt is not prohibited or discouraged by the regs, not only is it acceptable by them, but there are strong arguments for it to be good practice (remote switch off in the case of a fire/gas leak - similar to fireman's switch; access in the event of a trip is likely to be fully illuminated - no scrabbling around with/without a torch etc).
It may/may not be liked, but.....
Whats the concern or issue? You could install a meter cab over it with a keyed lock, instead of the typical ∆ keyThanks
