Bit of an outside question here but interested on hearing other electricians advice.
Im having the master bedroom redecorated and re skimmed this month and the bedroom is straight above the internal garage where the consumer unit is.
We have spoken recently about maybe doing a loft conversion upstairs in the future if we don't decide to move and I also want to do some rewiring work when I can be bothered to do it, the outside lights for some unknown reason are wired off a FCU in an upstairs cupboard that used to house the security system (I removed the system it a few years back) and I want to sort it out so i can run a few new outside lights.
The electrician in me is thinking that while I can make a mess should I run a 2.5 and 1mm cable up the bedroom wall from the consumer unit, into the attic and reel up at each end just to future proof any work.
The other consideration is I have a redundant 10mm in the attic already from the En suite shower I just removed. Do I use that to create a second consumer unit in the attic that I can then run any future supplies from.
Any thoughts? Me thinks running more cables for no reason other than I can is a bit of a waste of time.
