Discuss timeguard light switch in the Australia area at ElectriciansForums.net
Anyone know of anything similar to this
24 Hour / 7 Day Security Light Switch that can switch low energy bulbs of 7 to 12 watts, all the ones i have come across seem to want to only switch larger loads of 20W or more even the ones with separate fluorescent adaptors still say they are for larger loads - or do they still work with smaller bulbs?
Reply to timeguard light switch in the Australia area at ElectriciansForums.net
I have the typical LED on Dimmer switch. All the lights flicker in my house are very inconsistent times. By let me clarify by saying all the...
I have a 115vac line that tests with proper voltage and will power a low watt bulb but will not run a drill etc...
Line from main panel to barn...
Recently moved into a new home and replaced the main light fitting in the sitting room. We replaced it with this dimmable LED fitting:
ENDON...
Good afternoon,
We hired an electrician to replace the lights in our basement. Previously there was one circuit of fluorescent lights for the...
I have a 230 Volt single-phase circuit with a 100 Amp cutout fuse and a 100 Amp MCB switch, so the supply is rated at 23 kVA.
Only about 13% of...
