Discuss TT Installation in need of some TLC in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks for all your replys . I have purchased a 17th edition dual rcd CU today.
I have run the main earth to the earth rod , run the main equipotential. Floor boards up every where lol.
Had a look and the old CU and notocied that the lighting circuits still wired in old rubber cables :eek:
Thought thats strange as changed a few light fittings and never noticed them before.
checked all light fittings and their wired in T& E and all the switch wires are as well except for the one in my bedroom which is rubber.
Some ones been very naughty:mad: i will have to pull up a few more floor boards and find were its joined. Oh and looks like a bit of chasing out and replacing that switch wire.
I'am so lucky didn't want to put my feet up any way.:)
Mark
Hi Mark,
That old rubber cable needs to come out, as you are doing.
Perfectly fine in its day but it would have aged and will be starting to break down.
That would give your IR test some hell:D
They're actually ok, apparently made by wylex.
Im only kidding mate.
Trouble is, i get very frustrated fitting the cheaper units, as they can be fairly flimsy.
I have just for the first time, fitted a new GE CU and it had a plastic DIN rail!!!:eek:
Total Load = 0.8kw
Power factor = 0.85
Volt- 415vac
may i know the Current (A)
Thank you
I have answer = 4.02A
may i know the calculation to get 4.02A
tq
Total Load = 0.8kw
Power factor = 0.85
Volt- 415vac
Thank you
tq
Riduan, dont know where you get that from. Simple Ohms law V=IxR
So for 230V it would be (.8kw) 800W/230 = 3.48A
Leave the rest to you
may i know what root3?
tq
my frien told me
P=VI(COSQ)
0.8KW=240X IX COS Q(TETA)
THAT TRUE?
tq
my frien told me
P=VI(COSQ)
THAT TRUE?
Riduan
Dont mean to be nosey but how much electrical knowlege have you got?
The formula he gave is correct but use 230v and this is to work out power which you already know. Transposing formula so work out I is below
I= P/ V x PF
800/415 = 1.92A per phase assuming a purely balanced load, x 0.85PF = 1.63A per phase.
Now most of this is assumption as we do not know what type (if any) of power factor correction he has.
To get 1KW of true power at 0.85 power factor = 1/0.85 = 1.17Kva.
Nor do we know the type of load.
Reply to TT Installation in need of some TLC in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
