Discuss tt system with rcbo's in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
beaver74
in a t.t system i have all way thought you need a 100mA s type dp rcd covering the whole installation
been to a job today and it is a standard board dp isolator and filled with rcbo's which yes they will protect as for high earth loop but they are only single pole am i right in my thought's
My thoughts are that if every circuit is protected by a 30ma rcbo what is the need for a 100ma main rcd. I thought the 100mA rcd was to protect all "other" circuits when you could still have circuits on mcb only.
yes but i am thinking that rcbos in general are single pole as apossed to double pole main rcd
This configuration of board is probably what the IET intended to be the norm with regard to 17th Ed compliance. Can`t see a problem with it myself.
Its a very expensive way of doing it tho! U can get DP RCBOs but they take up 2 modules; I used a 30ma to protect swa running a supply out to a garage.
I agree that a board full of rcbo`s is way too expensive for many jobs in the domestic sector - the dual rcd boards are far more viable. Cost aside, rcbo`s just take up too much room in the currently produced boards!
I was under the impression that rcbo's were all double pole.That is why you have to connect the neutral into them and why there is a curly blue
lead hanging out of them-all I have seen and used have also been one
module type.Incidently they can be bought for around 15 quid a pop.
Reply to tt system with rcbo's in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Evening all, I have a little conundrum I need to get resolved. I’ve moved an EV charger from a single phase board that was on a 40a breaker and...
OSG Pg.40 says: '[Split CU with 2x RCCBs] is not suitable for an installation forming part of a TT system as there is insufficient fault...
7K
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
