F
fjr1300
There's one problem with this site - too much bl**dy information :devil2:
You think you've got your head around something and then you spend hours reading more posts and it does your head in :crazy:
Anyway for a crimper virgin, can some one explain where/why you would use the following crimps -
Pin Connectors
Spade Connector
Ferrules
Also on a double ferrule would you use say on a 2.5mm ferrule a 2.5mm size crimp tool or a 5mm one or do you need a special double head/die (See told you I know nothing about them)
Lee
Pin Connectors
Spade Connector
Ferrules
Lee
