Not sure why you want a higher replacement fuse
Yes. Shower cooker hot tub. Adding second shower wven with diversity I'm over budget. So requested a larger supply fuse.Perhaps the planned load is higher than 60A. Shower and a cooker nowadays and you're about at 60A.
I'll have to talk direct with Eon and clarify its their equipment not the customers. Maybe they think its the CCU breaker?
The DNO for your area is detailed on this handy map
http://www2.nationalgrid.com/UK/Our-company/Electricity/Distribution-Network-Operator-Companies/
Yes and downgrade too.You you need to contact the dno for the area not the supplier or meter operator they won't have a clue. Only the dno are allowed to upgrade there supply fuse.
I think he means tails from cut out.? Which will need metering supplier, but if tails from CU as you say.If bigger tails are needed from the meter to the consumer unit, that is a job for your electrician, not EON.
