Hello All
using the following units
KFX 100 Break Glass Reset Button
3FC F20 EU 2 units (both opening 2 vents)
3FC F10 EU 1 unit (opening 1 vent)
using auxiliary cards on 4/5 resistor in serious & parallel 480 series 10K parallel (came with units)
IO cards fitted through fire alarm & opening 2 panels & normally open pair from FP opening other box with 30v approximately.
Problem I am facing is press AOV break Glass & only the FC10 units goes Alarm,
can reset from any box & it resets fine. (FC 10 unit is Middle unit also)
Set off fire alarm all panels alarm & reset command works on any box.
Think I have checked wiring ok,
But Strange thing is that when Alarm mode is activated through fire alarm or through box the green lights stays on OK, yellow light not on but continuous noise through Break Glass & Red light on.
From previous experience Green light out, amber light on, Red on, Beeping on alarm.
Had problems last week as Velux sold relays boards to go in & these that were meant to link all panels & Alarms but found out after much talking with Technical that they were the wrong units, had in depth chat with them & they in turn with Denmark & eventually Window master.
Speaking with technical on Wednesday & waiting for 2 additional 4/5 cards to arrive, we discussed could we get all 3 boxes linked to one break glass reset unit & verdict was yes. Put into units yesterday 4/5 terminal boards & switched on & problem at top.
set up gone through so far
installed red & blue link in 2 panels blue on 9 red leg on 12 as shown, IF not connected shows RAUCHMELDER (smoke alarm fault)
first panel & second panel very close together put in other link on 9-12 shows fault, reversed & ok, all alarms out, if i don't turn on number one on pin out does not work well, nothing in book for number 1 pin out?
link across 4 & 5 panels alarm out & reset from any box or break glass.
just by having a look light emmitting diode are as
1&2 on break glass bring on amber light
1&3 bring on red light
will try module today with links to all 3 boxes in place just see if it works across "link" then tidy up wiring & check connections may even strip it down to individual boxes & build up to see when fault occurs.
anyone had similar issue ?
