P
Phillcbr400
Sorry can't access the alarms forums hence why it's here.
The plan is to move a veritas 8 compact alarm into an upstairs cupboard and have a remote keypad at the door. When fitting the keypad today just to see if all is ok (which it is), I noticed when I disconnected the supply and battery the bell went off. I understand this is normal due to the bell battery. My question is, when I disconnect and remove all the pir's how will I stop this, is there a code to de activate or reactivate the sounders?
Any help is appreciated
You wont' stop the external sounder all the time there's no power to it. It's designed to do that to stop little oiks from hammering it off the wall.
If you're only removing PIRS or internal devices, simply enter the customer code to silence - it will show a tamper fault (if wired correctly) until the PIR is reassembled and the lid put on, at which point customer code will reset the system.
Ill have to remove the bell wires aswell as the full unit is being moved. Looks like Ill just have to do the prep work first and make sure I work fast with connecting the bell up as priority. I've have the engineer code to disarm the tamper switch.
Thanks for the help
Old trick is to used the control panel battery, and connect to the bell box wires so you can remove the panel, connect the wire going to terminal A to the battery + and connect the wire going to terminal D to the battery -, this should hold off the bell until you relocate and reconnect the main panel again.
Will that trick the external sounder into thinking its connected? Ill give it ago, less time listening to an alarm going off is always going to be a bonus :) plus don't want to wake the old neighbours up from their afternoon nap time.
Presume it held the bell off then, ok you have till the battery runs down to relocate and power back up
should be fine until you reconnect the control panel again.
This depends how old the battery is ie more than 5 years then you may have problems why dont you just disconnect it or in the afternoon run the battery down 20-30 minuts. Remember if you go the battery route then fingers crossed it does no run flat at 3 in the morning
Yup, bells across sounder + and - should hold it off for a certain amount of time - alternative being to get up a ladder, sadly....
With oldtimer`s comments in mind, i hope 1. the battery is ok...2. your connecting the bell/battery and commencing work straight away.....as it could be embarrassing at 3am
Also remember if you connect straight to the battery its not fused and you do not want to see one of those batteries when they get a short across them.
Its ok to do this for 5-30 minutes but not 1-2 days
you had a vasectomy up a ladder?
fuse is to protect the control panel only, although bell units are now more complex, the charging circuit remains the same 6v battery and a 2.2k resister and diode wired in series, these regulate the charging current so even if the cables short the battery is protected, the old bell box batteries have a habbit of spliting open when there passed there sell by date
Just to correct myself, after reading another post with Oldtimer, were he is totally correct, and I have forgotten that unfused, any fault in the cable to the bell box, could be a problem of melting the cable....
Another way to avoid running the batteries down is to remove the bell box cover and disconnect the battery wires from the terminal strip.
Best wear ear defenders BTW.
Fair comment, yes though most SAB units are overcurrent protected now, but to be clear, I wouldn't run a bell hold off on any battery direct for more than an hour or two. Certainly not overnight, even if the panel battery is man enough to supply it on the end of the cable that long.
Just an old trick we used to do when changing a panel....never more than 20 mins to change over, saved getting the ladders out.
if its a texecom bell box then it will have a hold off mode that can be entered from the panel settings so that it doesn't go off when power is removed :)
simples !
Thanks for the input people. It will be getting done tomorrow now. I might even rig up a fuse carrier as a just in case tomorrow at work. The alarm has only been in about 4months. This is what happens when you take your girlfriends input "no we don't need a keypad" have it fitted then "yeah let's get a keypad" haha. Don't think it's a texecom bell box. Ill have another look for an hold off mode.
so your fitting an RKP to the front door...where are you moving the existing alarm panel from and why ?
Alarm is at the front door and is going to an old airing cupboard upstairs. It looks big a chunky where it is. RKP's just look nicer.
ohhh okayy :)
you should fit a premier panel and one of there elite keypads..
proper alarm panel and the RKP's look stunning, especially their flush mounted chrome ones :p
I would have done had I not been renovating a full house so every penny counts at the moment. Still the wiring is in place for the future if I ever want to get a nicer looking system. But the plain white led veritas RKP don't look too bad. Kind of blend in.
Couldn't get more simpler than a veritas ! Lol
Not enough options on the veritas, no expansion etc...
Good for DIY though
veritas 8c alarm
Security Alarms, Door Entry and CCTV (Public)
Phillcbr400,
shocking_eg,
