Discuss veritas R8 panel flashing green light in the UK Electrical Forum area at ElectriciansForums.net
A
amcjam
Hi
Not a panel I am familiar with, but asked to have a look. It has green flashing led on panel system has locked out, battery flat and charging voltage and aux reading 24.4v with battery removed.
Did power it down to regain control of system, but readings were still 24.4v.
any thoughts
amc
Try powering down the system then powering up. ....If this doesn`t work hard reset the system by powering up whist holding rest button.....There is no way you are getting 24v on aux, the transformer is only rated at 18v
hi tazz
thanks for that, I did power it down and was able to use keypad again, would a fault in the charging unit allow for this high voltage.
amc
Reply to veritas R8 panel flashing green light in the UK Electrical Forum area at ElectriciansForums.net
Afternoon all... The customer has a number of small green lights in the ceiling that are always on. This is a bed and breakfast/hotel. I had...
5K
Hi all, a very long time I did a swanky grand designs type new build in the middle of nowhere, so in the middle of nowhere that it's a house with...
I am having a flat roof constructed with solar panels over. As it is a cold, vented flat roof I will be having 175mm of Cellotex insulation...
Hi, My camper has a new 12v battery and I have wired up a split charge relay with a 100 amp blade fuse near van battery and a 100 amp blade fuse...
I have a Single Phase Power box for a townhouse. When I read voltage across the Hot legs (A) and (B) to ground I get 123 volts with the main...
