Discuss Volt drop on outside lighting in the UK Electrical Forum area at ElectriciansForums.net
Check the voltage input limits on the ballasts if they allow a lower voltage then you can go down to that voltage as a product standard applies. However do not push it too far or you will get lamp failure.
From my calculation (admittedly using 0.95 PF because 0.36 sounds very low) and disregarding all other issues of starting inrush current, etc.
Then the volt drop assuming ~half are 10m apart and ~half 15m apart and that the three twin fittings are at the end is about 12V and a basic ballast may allow input down to 200V. so you are well within limits.
Reply to Volt drop on outside lighting in the UK Electrical Forum area at ElectriciansForums.net
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
Hi everyone, I'm new here and was wondering if someone could help to get my college project calculations right. I'm about to start my 2nd year in...
8K
How does max volt drop for 25mm or 35mm feeds to sub CU work. Do we for example allow only 1% drop on the 25/35mm so we can keep 2% drop for...
Something I'm not quite getting. In table 7.1(i) of onsite guide the max circuit length of (for example) a lighting circuit on 6 amps, with rcbo...
Hi Guys, I'm doing my Level 3 C&G design project and just have a few design related queries which i am so far struggling to find clarity on...
