Discuss Wagossssssssssssssss in the UK Electrical Forum area at ElectriciansForums.net
I love wagos. The only 'frustrating' thing is that the 221 (slim, see through/orange lever) which look lovely, don't appear to be permitted to be classed as 'maintenance free' in conjunction with a Wagobox - whereas 222 (grey with orange lever) are. Regardless, still love them!
Ideal Spliceline are quite cool - as it sits dead 'in line' with the cable, whereas Wagos/Ideal levers require a bit of a bend. Not used them much though.
Ideal and Wago's are both rated at 32A when not used in maintenance free mode. For maintenance free installation you have to down rate them both (to 24A)
And these connectors are only ever maintenance free when installed in compliance with the maintenance free instructions supplied with the connector boxes (Wagobox, Wagobox XL and Wagobox XLA for Wagos and the In-Sure box for the Ideal connectors). Using them in any other way means they are not installed in MF mode and must be accessible for inspection.
My personal preference is Wagos because of the availability of the various Wagoboxes.
I 'think', the wagobox has to be secured with a zip tie in the given slot as well to be classed as MF. It's been a while since I rang them and had a chat though, so may be wrong.
I love the quickwire range of JB/connectors. Doing a switch and loop takes literally one minute no earth sleeving and maintenance free as well as small enough to poke up into a 1.5 inch hole in the ceiling to fit those there new fangeld lights where you have to take off the ceiling rose.
I remember when the first push fit wagos came out about the early 2000s
In UK wholesalers maybe. They were available from the likes of RS before that, and going further back I used to throw a few boxes in my suitcase when returning from Europe. I think they were invented in the 1950s but as usual in the UK we're a bit slow to adopt new materials.
I'm not into Wagoboxes though, I don't like the design, but it matters not, as they aren't needed for conduit work and I don't give a flying spoon about MF. They aren't used on the continent either.
What type of maintenance free push in connectors does everyone buy.
Never bought or used a single Wago to this date
I have removed a couple I found on a job
I replaced those with crimps,it gave me a feeling of it being a far superior method of making a safe connection
Hi all,
Here's a selection of the Wago connectors we have on offer.
Search results for: 'wago' - https://www.electrical2go.co.uk/catalogsearch/result/?q=wago
Our online offerings on Wago are being updated as we speak
Carriage paid ( UK mainland) is only £35 inc VAT and if our signed up for a forum account you get an extra 5% off all orders.
e2g-5-off-flyer-jpg.42743
Cheers,
Ivan
Went with andys recommendation and bought from Discount Electrical, Sorry Ivan i will have a look before my next order of them and before the next van stock order. Got a few sponsers to check out and comparenwith the wholesalers now.
Anyone seen these? I have been using them for 45 years and never had a problem!:)View attachment 48741
Fair enough TC..but these days sparks can't be trusted to install them correctly(I presume)
Then again, 'heating engineers' are a completely different animal.
Get this from last year, at a mates house. Installing a new boiler, breaking into a ring final circuit and doing it under the floor boards directly below the CU. (2 spare ways)
Reply to Wagossssssssssssssss in the UK Electrical Forum area at ElectriciansForums.net
Hello Can anyone confirm for me what the following spec for a Wago TopJob 2202-1201 din rail connector means? The connector can accept max 4mm...
I found these today so ordered some as I suspect I will need to extend a few cables when doing some work soon...
  • Locked
5K
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
