Discuss What code should this shower be? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all, I was with my senior yesterday doing a EICR for a domestic house. All of works are fine apart from this shower as shown below.https://Upload the image directly to the thread.com/5Egm5ez
https://Upload the image directly to the thread.com/nkXD5Sp
Shower is low and tiled around. I was suggesting to give it a C2 as water might get in contact for such low height. But my senior was saying it's just a C3 as the shower's cover didn't has any sign of damaged and is protected by RCD.
Just curious for you guys to code this, which code will be in your certificate?
Thank you very much for all your input.
Upload the image directly to the thread - https://Upload the image directly to the thread.com/5Egm5ez
https://i.Upload the image directly to the thread.com/5Egm5ez.jpg
Providing it's installed in accordance with the manufacturers instructions, no code. I did question such a situation myself recently when I was asked to remove a shower unit and move it to an en-suite where the shower had packed up. The ensuite had it mounted at about the same height.
Checked the manufacturers instructions and according to them it was OK.
Quite clearly no code if the case is undamaged and RCD protection is in place. They are all made to minimum IPX4 and are designed to get wet and route the water down and off the unit away from any internal spaces.
Reply to What code should this shower be? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Recently visited a new build to do a very minor job and spotted a few dodgy looking items so Client asked me to do an EICR. Following items I...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
I was surfing through one of the electrical training groups on Facebook yesterday and came across this question from an AM2 prep course: There...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
