Discuss What EICR code for plastic trunking in escape routes? in the UK Electrical Forum area at ElectriciansForums.net
Why would it prematurely collapse, it has to be put up in accordance with the building regulations which require a ceiling to have a fire rating, all of this speculation is assuming that electricians has sufficient knowledge of the fire regulations to make an assessment of the danger, this is a specialist subject that any electrician should not get involved with IMO not part of the remit.
Remember collapse isn't how we see it; we see it as failing before the fire-rated time for the material (30-60-90 mins etc), in actuality the definition for 'premature collapse' on this instance is collapsing before firefighting activities (S&R, fire elimination, damping down) is completed and the crew removed, NOT the materials failing their rated times.
Love him or loathe him @widdler (SparkyNinja) did a webinar (and a 'history of') on the Regulation (521.11.201), with the help of his old man, from the POV of a firefighter and why it was so important to understand the broader intention of this Regulation.
Webinar;
History of:
If it’s in plastic trunking or conduit it may collapse. If it’s above plaster board it wont. so no code.
And, assuming it was needed, how would you ensure continuity to each piece of metal grid strip?
Cross bond each bit, durr.....obvious.
Get a roll of 4mm single cut into 6" strips with a ring crimp on either end, then an impact driver and a box of self drillers and Bob's your aunties brother.
Oh, nearly forgot the 16mm back to the MET. I usually run four of them just in case some clown alters the ceiling and removes one.
Reply to What EICR code for plastic trunking in escape routes? in the UK Electrical Forum area at ElectriciansForums.net
Another thread asked about two circuits sharing a common multi-core cable and regulation 521.8.1 was mentioned. A friend of mine has inherited...
Hi all, Been asked to do EICR on thatched property for insurance purposes, however they will want all C3 codes rectified. Haven't seen it yet but...
Morning, Company had an external contractor coming in to complete an EICR recently. They have gave us the report with a C2 for holes in trunking...
Hi. Looked at a job this morning for remedial work on an EICR. The inspection has noted the plastic consumer unit within the hallway cupboard and...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
