Search the forum,
Discuss What is electricity ? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Nobody has mentioned electrical flow in the human body,the motor neuron,nerve system and it's generation...we wouldn't work without it;)
For years, it has been believed that electric bulbs emit light, but recent information has proven otherwise. Electric bulbs don't emit light; they suck dark. Thus, we call these bulbs Dark-Suckers.
The Dark-Sucker Theory and the existence of dark-suckers prove that dark has mass and is heavier than light.
First, the basis of the Dark-Sucker Theory is that electric bulbs suck dark. For example, take the Dark-Sucker in the room you are in. There is much less dark right next to it than there is elsewhere. The larger the Dark-Sucker, the greater its capacity to suck dark. Dark-Suckers in the parking lot have a much greater capacity to suck dark than the ones in this room.
As it is with all things, Dark-Suckers don't last forever. Once they are full of dark, they can no longer suck. This is proven by the dark spot on a full Dark-Sucker.
A candle is a primitive Dark-Sucker. A new candle has a white wick. You can see that after the first use, the wick turns black, representing all the dark that has been sucked into it. If you put a pencil next to the wick of an operating candle, it will turn black. This is because it got in the way of the dark flowing into the candle. One of the disadvantages of these primitive Dark-Suckers is their limited range.
There are also portable Dark-Suckers. In these, the bulbs can't handle all the dark by themselves and must be aided by a Dark Storage Unit. When the Dark Storage Unit is full, it must be either emptied or replaced before the portable Dark-Sucker can operate again.
Dark has mass. When dark goes into a Dark-Sucker, friction from the mass generates heat. Thus, it is not wise to touch an operating Dark-Sucker. Candles present a special problem as the mass must travel into a solid wick instead of through clear glass. This generates a great amount of heat and therefore it's not wise to touch an operating candle-type Dark-Sucker.
Also, dark is heavier than light. If you were to swim just below the surface of the lake, you would see a lot of light. If you were to slowly swim deeper and deeper, you would notice it getting darker and darker. When you get really deep, you would be in total darkness. This is because the heavier dark sinks to the bottom of the lake and the lighter light floats at the top. This is why it is called light.
Finally, we must prove that dark is faster than light. If you were to stand in a lit room in front of a closed, dark closet, and slowly opened the closet door, you would see the light slowly enter the closet. But since dark is so fast, you would not be able to see the dark leave the closet.
Next time you see what is called an electric bulb, remember that it is really a Dark-Sucker.
of course the earth is flat. if you look at a vapour trail of an airliner travelling at a constant height, the trail is straight as a die. if the earth was round, the vapour trail would be circular.
There are Flatearthers out there that would take you seriously and use your post to demonstrate we were all lied to thus the world is flat!
Wait until they find out that the sun is just the white hole opposite side of a black hole.:D
From the speed electrons move ,
(obviously due to the enormous numbers of them jiggling about doing nothing much)
Any of them tasked with doing some work ,
soon delegate that to another member in a very short time.
--Electron apathy rules--
( Electrostatic fields , and Light / Radio -EM waves may also generate a usable pd in semi/conductors )
Does time only progress when mentioned electron is present , but
observing it could cause a quantum load of problems .
( Does time move faster with the light off or on ?) off for me !
Time is just an illusion. Lunch time doubly so.:)
Reply to What is electricity ? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
