Discuss What to do with two additional red wires when using newer light fitting? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Sam bayer
EF Member
Bristol
I am changing a light fitting and have excess wires. I’ve matched up the three core wires for the feeds I have but have two additional red wires left (pic included).
What do I do with these? Just tape them off separately? Or should they be inserted somewhere?
Thanks in advance for any help! (I think the complexity comes from old wiring being used for a new light fitting)
FLICK
Electrician's Arms
Essex
Hopefully the power is off. Looks to me that the 2 reds need joining together to give a feed down to the switch.
GMES
Admin
Staff member
Admin
Under the banana tree.
Means he's posted the same thing twice.
KEV 1 N
Electrician's Arms
Durham
Nothing complex, it’s a standard wiring method called “Loop in”
OP
Sam bayer
EF Member
Bristol
Thanks Flick. Power is off. So to join together can I just twist the ends together (of the two red wires) and the. Surround with insulating tape?
KEV 1 N
Electrician's Arms
Durham
A connector block would be better
FLICK
Electrician's Arms
Essex
Don’t even think of that. At a minimum they need to go into another choc block beside the other 3.
dinger809
Regular EF Member
Essex
Put the two reds together in a connector block and put insulation tape around everything to avoid anything accidentally falling into or touching the screws or connections
OP
Sam bayer
EF Member
Bristol
Are you certain the wires correspond to L .N. E at the lamp end?
Pretty certain yes - I matched the colours and everything seemed logical and made sense.
Thanks for everyone’s quick responses - I’ve just ordered some connector blocks from amazon so will wait until they arrive before I complete the job.
ruston
Respected Member
Mentor
Electrician's Arms
Trainee Access
Northumberland
You need to be certain , not pretty certain.
The wires in the pic look very difficult to identify . It could be very dangerous if you have it wrong . You cannon take chances with this .
What is the lamp wiring colours, and what colours have you connected to them , and are you certain you have the red sleeved that we can see in the line conductor at the lamp?
Rpa07
4000 posts - only 54195 behind Telectrix!
Electrician's Arms
Bristol
Now we need a ‘shakes head’ button!
Sam why would you order connector blocks off of amazon - could you not go to the local hardware shop?
‘Shakes head’
Shoei
Regular EF Member
nantwich
It's not clear what's hanging off the wire but if it's just a regular pendant do think about using a ceiling rose, this kind of thing, they cost very little, have nicely insulated terminal blocks and strain relief for the cable to keep the weight off the connections.
Wilko
Electrician's Arms
Berkshire
Hi Sam - it might be just me not being able to see, but how the heck do you pick out the earth on the flex from the light?
45140
Regular EF Member
Midlands
Have you have tested the circuit before and how will will test the circuit afterwards as required by the Wiring Regulations ?
Also is there just a single earth as there is only one G/Y sheath.
As Shoei has said above you really should be using a proper ceiling rose which will get rid of the connector block - which cannot go into the void wrapped in tape, but needs an enclosure as stated in the Wiring Regs.
SparkyChick
Making a banana smoothy for my fave gorilla
Staff member
Moderator
Mentor
Electrician's Arms
Solar Guru
Trainee Access
South Wales
As has been said, the connector block should not be stuffed into the void, but it will usually be contained by an enclosure (that requires tools to access - the body of the lamp) that will usually contain the strain relief for the cable.
dinger809
Regular EF Member
Essex
You are joking of course ???
My apologies and to the OP. It was inappropriate sarcasm based on what will probably end up happening anyway
As the others have said here, the connections, for safety, should be in an enclosure, such as a ceiling rose or a Hager J501.
But most importantly, don’t guess it, if you’re unsure, please call a reputable electrician
Permanent unswitched live colour?
  • Brown
    Votes: 61 67.0%
  • Black
    Votes: 30 33.0%
Electrician Talk
