S
Sam bayer
I am changing a light fitting and have excess wires. I’ve matched up the three core wires for the feeds I have but have two additional red wires left (pic included).
What do I do with these? Just tape them off separately? Or should they be inserted somewhere?
Thanks in advance for any help! (I think the complexity comes from old wiring being used for a new light fitting)
Hopefully the power is off. Looks to me that the 2 reds need joining together to give a feed down to the switch.
Thanks Flick. Power is off. So to join together can I just twist the ends together (of the two red wires) and the. Surround with insulating tape?
Don’t even think of that. At a minimum they need to go into another choc block beside the other 3.
Put the two reds together in a connector block and put insulation tape around everything to avoid anything accidentally falling into or touching the screws or connections
Are you certain the wires correspond to L .N. E at the lamp end?
Pretty certain yes - I matched the colours and everything seemed logical and made sense.
Thanks for everyone’s quick responses - I’ve just ordered some connector blocks from amazon so will wait until they arrive before I complete the job.
