Discuss What to do with two additional red wires when using newer light fitting? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I am changing a light fitting and have excess wires. I’ve matched up the three core wires for the feeds I have but have two additional red wires left (pic included).
What do I do with these? Just tape them off separately? Or should they be inserted somewhere?
Thanks in advance for any help! (I think the complexity comes from old wiring being used for a new light fitting)
Means he's posted the same thing twice.
Put the two reds together in a connector block and put insulation tape around everything to avoid anything accidentally falling into or touching the screws or connections
Are you certain the wires correspond to L .N. E at the lamp end?
Pretty certain yes - I matched the colours and everything seemed logical and made sense.
Thanks for everyone’s quick responses - I’ve just ordered some connector blocks from amazon so will wait until they arrive before I complete the job.
You need to be certain , not pretty certain.
The wires in the pic look very difficult to identify . It could be very dangerous if you have it wrong . You cannon take chances with this .
What is the lamp wiring colours, and what colours have you connected to them , and are you certain you have the red sleeved that we can see in the line conductor at the lamp?
Reply to What to do with two additional red wires when using newer light fitting? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hello. I’ve been racking my brain all day with this. Here is my situation and question: I have some OEM ambient lights in my vehicle. They are...
Hey, I have a shed in my garden that was built and wired up by my granddad a lonnng time ago and it currently uses 2 core/twin and earth cable...
