- Reaction score
- 259
"Hello All",
As this might be seen as an insignificant `problem` I tried to post this in the DIY section but there was no `New Thread` button showing and my `Status` was showing as `You may not post` - `You may not edit` etc. on that Forum webpage [I was logged in] however I may get more views here.
I Apologise that my explanations below have made this message so LONG - about Lightbulbs !
I have got a possible problem regarding not being able to use the same Phillips Energy Saver Lightbulbs on my Home`s Digital Security Lightswitch Timers that I have been using for YEARS [in 7 Rooms]:
I have had Digital Lightswitch Timers on most of the `Main Lights` in my Home for about 15 Years or more - since the availability of Energy Efficient / Low Energy Lightbulbs [`Lamps`] I have been using `Good Quality` 20 Watt Bulbs.
As I was always aware that the cheap Low Energy Bulbs were NOT suitable for Dimmer Switches or Timers I started off using Osram 20 Watt Low Energy Bulbs - more recently I have been using Phillips 20 Watt Energy Savers - bought a few Years ago.
Before I started using the Osram Low Energy Bulbs I contacted Osram to ask about using with the Timers - they told Me that as long as the Bulb did NOT `Flicker` when the Light was Off their Bulbs should be O.K. to use - when I could not find the Osram Low Energy Bulns I contacted Phillips and was told the same.
None of these ever showed the `Flickering` that I associate with a slight power `leak` through the Digital Timers [?] - I did try a cheap Low Energy Bulb many Years ago to see if / why they would not be suitable.
At that time there was no indication on the boxes that any of these Low Energy Bulbs should not be used with a Dimmer Switch or Lightswitch Timer so although I did check with the Manufacturers I thought at that time `Good Quality` / Known Manufacturer = suitable for Lightswitch Timers - Cheap `Supermarket Special` Low Energy Lightbulbs = Definitely NOT !
NOW THE PROBLEM:
One of the Low Energy Bulbs blew and as I still have a couple of the Phillips 20 Watt Energy Saver Bulbs [from the same batch purchased] I replaced the blown one with the same type - only to find that I got the `Flicker` on the Bulb when the Light was turned Off.
I tried another Phillips 20 Watt Energy Saver - this also Flickered.
I tried these 2 Bulbs in some other Lights - they Flickered in those Rooms also.
This happened during the Week so I contacted Phillips but I could not get to speak to their Technical Department for Lighting products - instead I was advised to submit an enquiry / message on their website as to whether they think that I have 2 Faulty Energy Saver Bulbs OR whether something in the Manufacturing process changed some time ago rendering these 2 Bulbs NOT to be suitable for use with Lightswitch Timers ?
With a Company of their size I will be expecting to wait quite a while for an answer - so I wanted to ask for recommendations from Members who might have come across this situation before.
EDIT:
As I could not find ANY `Dimmable` Low Energy Light Bulbs on the Phillips Lighting website I now doubt whether they will state that these 2 Energy Saver Bulbs are suitable for my Lightswitch Timers.
BUT Why would I have NO problems at all for YEARS using these Phillips Bulbs - until I try to use the last 2 of a purchase of 10 Bulbs ?
Unfortunately I am unable to go anywhere this Weekend / Week where I could buy `Good Quality` / Known Manufacturer` / Phillips or Osram 20 Watt Low Energy Lightbulbs - BUT I wondered if any Members had recommendations for Low Energy Lightbulbs that are suitable for Lightswitch Timers / Dimmer Switches ?
I have not been able to find the OSRAM 20 Watt Low Energy Bulbs that I used to buy even online - perhaps they have been discontinued ?
At present I am using a 70 Watt Halogen Bulb [GLS] in that Light - but I don`t really want to have to dispense with using the 20 Watt Low Energy Bulbs and go to 70 Watt Halogen throughout my Home because I might as well go back to the 100 Watt Bulbs.
Although the Low Energy Bulbs do last quite a long while from MY experience I don`t really want to be paying ÂŁ8.00 or ÂŁ10.00 each for lightbulbs unless there are no alternatives ? [I have looked online ÂŁ8 +].
Thanks for reading this LONG message ! and Thanks in advance for any recommendations.
Regards,
Chris
NOW THE PROBLEM:
EDIT:
Regards,
Chris
