Discuss Willing to change a 2 way that would simultaneously turn the light on.. in the Lighting Forum area at ElectriciansForums.net
I've got a customer with 2 way switches which I want to rectify it in such a way it would simultaneously control the single light fitting. The original switch only turns ON the light if BOTH switches are ON.
The original configuration is the permanent live goes to L1 then when I switch it, it goes to common, then it goes to the common of the downstairs switch and when I switch that aswell it then goes to L1 of the downstairs switch back to the upstairs switch on L2, then the L2 got another wire to the light switch which then turns that on.
I came up with an idea with putting L2 and L2 together. L1 and L1 together. Then run a permanent live to one of the common of 1 switch. Then the other switch, put a common which then will go the light. This will make the customer switch from both ways.
Just to ensure is this safe? I have been away from electrical work for 14 years thats why I'm double checking. I am qualified btw. )
Cheers
Cheers
Sounds like whoever installed them made a bit of a basic error. Has it always been like that??
Yep the customer states that it has been like that for donkey years. I don't really get it why do some people wire stuff wrong even though they have some sort of qualification etc. While being at it I have also seen that the light in the kitchen has 2 switches controlling it. The lunatic "electricians" have put a permanent live to the common of the first switch then when I switch it, it goes to the L1 then to the common on the other switch, then when i switch that one it goes to the L1 then another wire from the L1 is running to the ceiling rose. However there is another black wire that servers absolutely nothing. Its just looped from L1 of one switch to L2. It seems that it was disconnected all this time. It took me around 25 minutes running around and trying to chase these wires until I found out that the black one served no purpose!
Can't believe someone would attempt to wire a 2 way lighting circuit up for a customer when they don't know how to do it.
If the right amount of cores goe to the right places and it is wired wrong, I would normally assume that at some point some diy has been done and the switches have been changed or removed for decoration.
Exactly my thoughts. There's no way it would have been like this from when it was installed. Someone has tampered and got stuck!
Yeah suppose so, however the electricians back in 1950 etc probably did not have much knowledge or they just didn't adhere to the rules. I'm currently using a neon test light to verify voltages but the question is if you don't have a neon light, how would you test for voltage as the neutral is on top of the ceiling only. Only dealing with lives so cant test with a approved tester or a multi.
Electricians in the 1950s knew how to wire a simple 2 way lighting circuit.
I think I'd suggest getting a sparky in for this one to be honest. No shame in knowing your limits.
Yeah suppose so, however the electricians back in 1950 etc probably did not have much knowledge or they just didn't adhere to the rules. I'm currently using a neon test light to verify voltages but the question is if you don't have a neon light, how would you test for voltage as the neutral is on top of the ceiling only. Only dealing with lives so cant test with an approved tester or a multi.
That last point has been answered in your other thread
Reply to Willing to change a 2 way that would simultaneously turn the light on.. in the Lighting Forum area at ElectriciansForums.net
i know about the different wiring arrangements for 2 way light switching. i want to connect the permanent live into first switch common, connect...
Hi boys and girls. I have been flying around my house and I have been seeing a lot of two way switches used instead of when a one way is only...
