Discuss Worst Consumer Unit Pictures Thread! in the UK Electrical Forum area at ElectriciansForums.net
Dan
Staff member
Admin
Mod
Heard about one CU being wallpapered. Wondered what the worst you've seen is, and pictures win prizes.
The one on the left had two wylex fuses hanging in there without the ceramic fuseholder. Thats (on the left) an MEM C/U. And an earth from the MEM in 2.5 T&E!
Sawdust can create an explosive environment! Could have been quite a blast if there ever was a bad connection and the conditions were right.
Looks like the CU in a Heroine processing plant! What a picture. What IP rating was that again?
Not at those levels of compaction! :)
Westward, I hope you've tendered your multi million pound particulate extraction solution?
Before I took the cover off it was compacted. Was doing an EICR and took ages to find it, maintenance had no idea it was there. If they did any works on the circuits from it they used to knock off its 63A supply breaker. The extraction chamber had been built around it and is probably still the same. No chance of an explosion in there I doubt it contained much oxygen.
On a PI once in Sheffield, after an hour or so of looking around, I found the old 4 way Wylex behind an obscure panel half way up the stairs, Don't bother asking where the meter was ...
Reply to Worst Consumer Unit Pictures Thread! in the UK Electrical Forum area at ElectriciansForums.net
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
I was just googling for skeleton boards after reading the last thread and various pictures of consumer units popped up, some wired terribly and...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
