Currently reading:
Y-plan Issues - quick help needed please!
Discuss Y-plan Issues - quick help needed please! in the Central Heating Systems area at ElectriciansForums.net
Did it work correctly before you made these changes?
Are you an electrician? Is this a job for a paying customer?
1 - very intermittently, timer wasn't working. Thermostat was from the 60's.
2 - no, not a qualified one.
3 - possibly, but I was seeking advice from Productive members... Not a game of 21 questions.
1, Ok, did you test the whole system through before making any changes to confirm that diagnosis? Are you sure that all of the other parts of the system that you haven't changed are functioning correctly?
2, for the sake of not starting the usual riot I'm going to stay quiet on that one.
3, Who's playing a game? If you want advice then you need to provide all of the information, if you don't then people will ask for the information. If the system was originally fitted as early as the 60's then there is every possibility it started life as a gravity system which has been adapted into a fully pumped system and may not be following the standard y plan.
I have already advised you as to how to test the system to find the fault, you go through each point in the control system testing that it becomes either live or dead as expected when each control is operated.
Wind yer neck in bonny lad..
When you go to your GP with some ailment or other, do you just sit in the chair and expect him/her to diagnose the problem without asking or you replying to questions??
(s)he is not telepathic and neither are we!!
After re-reading it I may have taken number 3 the wrong way!
Its for myself on my home!
Apologises!
1 - No, I diagnosed it as the thermostat to start with. Replaced that, and it was still very intermittent, so also changed the panel (also for cosmetic reasons as I had a hideous Dandfoss Randal!) yes, It is gravity fed... Is that where the problem lies?
2 - yeah your right, but I like to give things myself a go first and see myself as quite handy. Although I will never touch gas / mains electic.
3 - sorry I think I miss understood your initial post! It is a gravity fed system. So maybe I'm looking at a different plan?
Cheers
It can't be a gravity system now if it's got a 3port mid position valve and a Worcester Ri boiler, at least not without something very unusual going on!
Don't get me started on Randall programmers, I can rant about them for hours!
You say you won't touch mains electrics, but here you are working on and asking about mains electrics?
I would suggest you are at a point where calling an electrician in to fix the system is probably the most sensible option. But try to make sure you get one who actually understands heating controls, there are many who pretend to be electricians but don't.
That's the issue everything is set up like a Y Plan, but I have a tank in the loft which feeds the system. Any ideas? Or call in the 'experts'?
How many tanks in the loft, and are they big tanks or little tanks?
A small header tank would signify that you have an open vented heating system, and a large cold water storage tank(s) would suggest your hot water is from an open vented cylinder. Neither of which has anything to do with whether it is a gravity or fully pumped system.
If it all appears to be set up as per a Y plan then it'll be fully pumped. I only mentioned gravity as it is possible that with the age of the parts it may have been converted from one to a fully pumped system and so may not be following the 'wire by numbers' type of setup.
Call the experts. A tank in the loft does not mean it's a gravity heating system, the HW and CH are more than likely pumped.
And as Dave said, get someone who understands heating. You'll end up replacing every part until you find the fault, penny wise pound foolish!
grfeg, if you post your location, 1 of us may be close enough to help ( shut it , geordie! LOL.)
Hi telectrix,
I'm from Barrow In Furness, Cumbria.
I've phoned all around today and earliest is Monday. Luckily it isn't too cold at the moment!
I managed to get the pump running earlier, but the boiler didn't kick in. Once I switched it off and on again it didn't come back on....
That maybe a clue for one of the genious's who could work out where the wiring fault is, or what I have wired up wrong!
Cheers
the comment was made in anticipation of your imminent sarcastic reference to my skills with heating systems.:ack2::49:
...Sounds more like an issue with your boiler,than the control side...I would advise getting someone who is familiar with that model,and isolate the control side,bridge out the HW/CH and actually see the boiler function correctly.
Good luck :icon12:
Can somebody help me out please. I've been let down twice now by leccys in the past fortnight.
Has anyone got a diagram or know how to just get the central heating on, using the controls on the boiler. Basically override the 3 way valve, and by pass the thermostat and control panel.
its a Worchester Greenstar RI.
Thanks for your help.
Without seeing the system it is very hard to advise how to bypass the controls safely, some types of hot water storage need overheat protection as they can explode in a most dramatic fashion if they overheat.
The problem with a 3 port valve is that with it latched open manually it will be heating both DHW and CH without control.
Hi Dave, Thanks.
Its not an issue if I latch the valve open, as it will just feed the hot water tank and circulate. I won't be leaving the system running for any longer than 1 hour really. Just enough to heat rads and tank full of water!! Unless I am missing something...
is is there a way to miss everything out, just have the pump and boiler running? I will check that link now Teletrix, thanks mate
You need to put a link between terminals L and LR to get the boiler to fire up.
But I should warn you that unless you are gas safe registered you shouldn't be removing the cover off the boiler.
Charming and the same to you Geordie!
Do you never watch rogue traders or watchdog that's what they say. And over on the plumbing forum if someone asks a question like this they always get closed and advised to get a GSR engineer.
I was only warning the guy not telling him not to.
Bollox!!! :laugh:
What he says up there!
You're not interfering with gas/combustion parts of the boiler.
Would you trust a GSR plumber to do the electrics? Probably why it doesn't work! :)
Reply to Y-plan Issues - quick help needed please! in the Central Heating Systems area at ElectriciansForums.net
