Test procedures as per BS 7671 would be my choice. Would be interesting to know your reasons for wanting to test Zdb prior to dead testing.Hi guys got my assesment in 3 weeks and want to get my testing spot on. Little confused whether to test Zdb on 2 way CU before dead tests?? Or do I jump straight into continuity? Thanks in advance.
Dead tests should always be done first before live tests for safety purposes.
As you are not being inspected on safety, personally I would not worry to much. However if you want to donit by the book then dead tests first.
Yes. Why you ask?Did you install the submain?
Yes. Why you ask?
Surely you undertook all of the tests (live and dead) on this circuit?Yes. Why you ask?
Technically there is no such thing as Zdb the measurement at your two way CU is Zs.
Not to my knowledge, no.
I agree but not a abbreviation I ever quote. I believe it has been adopted where a true value of Ze cannot be established due to operational restrictions and the value is often referred to as Zdb which although often quoted is not a recognised abbreviation.But widely used
