Discuss "disconnected" old immersion heater point gives a reading on fluke tester in the UK Electrical Forum area at ElectriciansForums.net
J
jonboy2015
A relative has asked me to install an electric shower. He suggested i use an old electrical point that used to be used for an immersion heater, but has now been plated off with a blank plate and the live and neutral wire inside have been taped off with red insulation tape.
I used my fluke clamp meter to check if the old wires of this old immersion heater point are still live and i get a 0.1 V ac readings when the clamp is used around the wires. To check things further i checked his consumer unit which is a wylex unit with his properties circuits split into 2 x socket RCD's on one side and a lighting RCD and a Cooker RCD on the other side.
Now, i'm trying to distinguish where this old immersion heater wiring is being supplied from and would it even be sufficient for the new 8.5 Kw Mira shower. I knocked off each RCD individually while testing the reading of the old wiring and each time it still shows 0.1 V ac regardless but when i knocked off the main 100A isolator the reading shows a 0.0 V ac reading. Can anyone help as to where this wiring could be possibly getting its supply from and is it sufficient wiring anyway? or should i simply run a new 10mm from a 45 A RCD at the consumer unit to supply his new Mira shower instead? Any help would be greatly appreciated folks! :)
Are you a sparky?
The 0.1v is a meaningless reading. Did the circuit test at 230v when all the circuits were energised?
The 0.1V is induced from another circuit and negligible (disregard it). The Immersion will most likely be 2.5mm so not suitable for electric shower (unless you are having a hand wash as a shower :) )
if you think an old immersion heater feed is adequate for a 8.5kW shower, then i'm afraid you're out of your comfort zone here. thew shower will require a 6mm dedicated radial. if you can't work it out, give me a call.
It's Friday the 13th,, right?
Reply to "disconnected" old immersion heater point gives a reading on fluke tester in the UK Electrical Forum area at ElectriciansForums.net
Until last week I had a dual tariff electricity supply with a cheaper overnight tariff. This was good for the storage heating, but now the storage...
I have an existing but unused 50A disconnect on the side of the house. It had been connected to an AC unit that got replaced. It has just 3...
90s house electric issues continues 🥲 So after getting some good advice here I've managed to sort out some of the heating issues so thank you...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
