Poor man’s chandelier
Had their rep come down to sell their wares and all looked good but the product codes were wrong with what they demonstrated. they stated one code was rated at 40k per fixing when it was actually 20k. the fixing had a part that clips through unistrut (now known as the weak link) under load it just pulled through and once one had gone there was no stopping the rest running away. The 40k version actually just omits the unistrut clip and the wire is just sleeved and looped through a hole.
what type of fixing was it?
usually for us its raw bolted unistrut to ceiling then everything else hangs off that
It was a product called zipclip. Basically you still a 6mm hole, then you have an eye bolt basically that you just bang in which none had failed then the wire comes off that
Reactions: daniel sinclair
At a secondary school, this is a MCB which has been siliconed onto the side of a dimmer unit enclosure. I spotted this within a month of the dimmer unit going in but all of a sudden everyone involved, from contractor to site service manager to governors suddenly turned into the three wise monkeys. They didn’t feel too clever though when the application for the entertainments licence was turned down because of it, and they had to cancel the show for which all the tickets had already been sold.
ImageUploadedByTapatalk1427235728.588181.jpgImageUploadedByTapatalk1427235777.724189.jpgImageUploadedByTapatalk1427235807.014364.jpg
The first two are from when i used to follow plumbers around, good little earner that was.
The third one, well i just like the pipework
Reactions: 2 people
ImageUploadedByTapatalk1427236648.326585.jpgImageUploadedByTapatalk1427236699.991276.jpg
Another skilfully completed job (in the eyes of a plumber)
Oh i forgot to add, hope that fuse never needs changing, or the spur inspecting in an eicr. (Just to clarify, i did move the spur and all associated wiring, and all the temp connections were already made when i arrived, because he wanted it tested so he could wrap up) i just laughed, then politely asked him to remove the boiler so i could access the spur.
that was left after builder crew doing new kitchen and downstairs work.
they had someone for new kitchen, and told the customer she needs another spark for big rewiring.
in the meanwhile reconnected it with some new cable,
fair choice from them and some work for me :-)
8K
Darkwood,
mainline,
