Discuss help to wire combi boiler for underfloor heating and house radiators in the UK Electrical Forum area at ElectriciansForums.net
I'm a bit muddled after seeing the common thermostat connections, is it all connected in a temporary configuration because it doesn't look right to me. Apologies in advance if I'm wrong!! I've also noticed it says wireless on the control centre, any reason for it?
I meant to say that this wiring centre requires that the room stats send back a wireless signal back to it. The reason that I'm going back to using a joint box method is that The kit didn't come with wireless stats so I was just going to use altech 230v dial ones. All connections at wiring centre are temporary at the moment
easy enough to do.
Reply to help to wire combi boiler for underfloor heating and house radiators in the UK Electrical Forum area at ElectriciansForums.net
