How tight are the bends? Cobra with a tennis ball or small Coke bottle on the end will slide straight over the corrigations
rat and a ferret. no problem.
We have a ball attachment for our Cobra that would do that easily , I think they do a 6mm version which may help with being that bit more flexible .
Also as suggested a decent road compressor and a carrier bag should do it , but I prefer fishing line instead of string .
Once had a car park lighting duct with rope in but blocked, local labourer fetched his ferret in with a ferret finder and found where duct was blocked in about 10 min.(crushed by rocks compacted by JCB )
Hi,
As Lee and Martin have said, Compressor and placcy bag, I've used this on more than one occasion and it's always worked.
Regards.
30 meters is pushing your luck especially with corrugated wall ducting. You could try but you'd need to use an end attachment that looks like an egg whisk.
I saw something just like that on telly a couple of weeks ago.
It was a program about Instruments of Torture and this thing had a screw that made the diameter expand when turned.
I'll leave the rest of it to your imagination ...... :devil2:
