Guest viewing is limited
Darkwood
(Taken from Facebook)
A customer called me and asked if I could have a look at a connection he had performed on his generator. The cable he had attached to the generator was a 3x95mm2 aluminum. The main fuse on the generator was 400Amps! I did not approve.
He might not have a crimp for 95mm. All he had to do is hire one for the day and put the cost on top of the job!!!
It is these sort of things that cause problems for the next electrician. Soon as you see that and you tell the customer that you can not touch anything until that is rectified (at an extra cost), the normal reply is "well, it was done by an electrician and it has worked for years". Time to pick up the tools and walk away.
Preaching to the choir I reckon mate - the sort of 'sparks' that do this won't be bothered enough to come on a forum like this I reckon
The pic will be here in a few months , when some one finds the bodge the QS of a Niciec reg firm did yesterday. he had to move the 45A cooker switch in a highend newbuild. new backbox 30cm to right of old place ,joined the 10mm twinearth in the old box, cut 2 cores off of cores to fit in yellow crimps and then filled the box with silicon it looked like jellied cables. some one could easily hit the cable as it is now out of zone .
Out of interest, did the old backbox have a blanking plate fitted to to it? Daz
nope it might be covered by the hob wall protector. it was i real mess cant believe the builder agreed to it , it took him half a day , i would of put a holesaw thru the plasterboard ceiling in edge above new switch and as a shorter run pulled same cable up and put it down. i would definately have a bit of mess to sort out than non compliance with cable not in zone no access to joint etc
Even better still, who saw the need for the wedge to hold the door open
They probably couldn’t find a fire extinguisher to plonk against it.
This is what really happens when you don’t know your ar$e from your elbow.
Here is a couple from a job I was called to, the rewire had "just been finished by an electrician friend"
I suppose at least one of the "busbar earths" was correctly identified!
Sent from my SM-A300FU using Tapatalk
Also have this beauty
These were feeding an garage board supplying an electric shower on a 50A MCB.
Also, the water bond was taken from aforementioned garage board!
Conductor size: three sevenths of 16mm!
that is a deffo bob the builder. even a plumber could do better.
what, country and western? as in my wife's run off with the dog and the milkman's shagging the cows?
8K
Darkwood,
mainline,
