Tails of the Unexpected.......
Found this on a farm on an EICR....!!!
The SWA goes straight to the pole next to the barn where it is stripped and joined straight to the overhead supply!!!
No meter either!
Sent from my iPhone using Tapatalk
Reactions: 5 people
No meter either!
That's a good way to PME a supply :nono:
No meter either!
Private overhead or DNO overhead?
The overhead is on the customers side of the meter.
Looks like the farmer done it himself!
So it's a private overhead.
How old is the overhead? On a farm it is still possible to find the old old old TNC overhead distribution circuits
That is exactly what it is, never seen it before.
It's 10mm tails on a 80m run on a 100a fuse.
Lovely job lol
Lovely job lol
I'm not surprised, it's as rare as rocking horse poo these days thankfully!
It would have to be 13th edition at the latest. The fact that these still exist is the reason the regs about them still exist (see PEN conductors) to allow them to be maintained despite being illegal to install new now.
The overheads should be 'hard drawn' copper rather than standard soft drawn cable, and can be bare conductors if on insulators. The CCC is higher due to being in free air and not exposed to touch.
We had a stock of imperial hard drawn red and black where I served my apprenticeship in the stores left over from jobs on local farms.
The drop cables would normally be connected using line taps (basically a split bolt and nut) I think TLC still list them bizarrely
Reactions: 4 people
As an apprentice, I once had to work an an "Electrical Engineers" house of whom we were also working at his place of work, a big pharmaceutical company based near to Euston station.
At his house, from memory in a garage or utility area, we were to tidy up some wiring that was laying on top of some wall units.
This was micc cables - in use with connectors on the bare ends - no pots or compound. I'm not sure how long it had been like that, but it was a small miracle that not only was the circuit in use and working, but hadn't killed anyone or caused any damage.
He was probably good at shuffling paper and quoting regs, but not so great or intelligent with the practical side, and no doubt on poo loads more money that the sparks I was with.
Sounds about spot on,
Apart from the drop cable is a bit of SWA just stripped back and joined with 60amp choc blocks lol
I looked at Pen conductors during the EICR but due to it saying that they cannot be used within an installation I disregarded it completely and assumed it was a massive bodge up!
Apparently it hasn't been tested since installed lol.
Thanks for the information.
No worries.
It is still definitely a massive bodge up, no question about it.
I don't think it's possible to justify anything other than a repair to an existing TNC install, I don't think extending it and adding another DB would be justifiable by any sane person now!
Amongst numerous other issues in the piccy, the one that hindered me was I couldn't get CUs cover off. I think the gas meter must have been changed to have the raised up part on the left hand side at some point. Idiots!
That raised up part at the left is the regulator, which reduces the pressure from the incoming service pipe to that required for the installation, and maintains the pressure.
I think, but am not certain, that that is quite an old type which requires mandatory notification to the gas board for replacement whenever a gas safe plumbob encounters one.
Reactions: NDG Elecs
just get the gas supplier to shift the stupid gas meter at their expense. ​whoever fitted it there is an arse.
Reactions: 3 people
Not as good as TheGayOwl's but I had this the other day. The cu cover wont close as the door casing impinges on it. The space is to small to get a normal screwdriver in to remove the far side retaining screw and the cover doesn't sit flush in any event (see the top).
Top of the board!
Henley's to the side of the CU. The exposed conductor is the Live.
The shower unit the Henley split feeds.
The meter tails were approx 8m from the DNO cut-out and unprotected.
Top of the board!
The knob obviously didn't have any glans on him.....see what I did there!
8K
Darkwood,
mainline,
