I wonder what the breaking capacity is of a fuse wire sandwiched between 2 MCBs?
Any old breaker will do....
Not so much trade pic, but anyway Guy calls me up because he can't get any power to work in his garage, so turned up to take a look.
Straight away he goes on about how he has wired up many garages, its really easy.
Took cover off the DB and, it confirms my suspicion he didn't know what he was doing......
Also, what's the incoming supply and cable size, looks pretty small for if that board were to get more loaded?
OOH! My metal plate thingies aren't shiny like those two at the bottom....mine are covered in some boring plastic stuff...I must take that off and get the brass polish out...
Of course it wont work, the main switch is off!
How come the tiles are so clean?
  • Funny
Reactions: SparkyChick
Because they’ve been cleaned but the switch left to be changed - it was the tidying up of a flat in the same house that I was sorting a lighting problem so I was having a look around - invited of course!
Ah that makes sense. Dirty scatters.
I should have said that it was the 2019 range from BG Nexus it’s called ‘Chinese kitchen’!
Apologies to BG if you are listening - love your unswitched sockets!
  • Funny
ME.....Why did you do that?
Plumber...... I assumed it was dead ME....Why would you assume that? Plumber...... Dont Know.......... ME.....Move all of it..... For the sake of the forum all expletives were not used
What really annoys me about that is the plumber could easily have done that neatly, avoiding the socket. It's not difficult, ffs...
Clearly, if he couldn't be bothered to check if the socket was in use, and anyway just went ahead and fitted his pipes, badly, he should be sacked.
"Push-fits" do not a plumber make".
That picture has actually made me very angry!
8K
Darkwood,
mainline,
