go through the questions : answer those you can be 100% sure of even without opening the book. probably 20 -30 done: flag the rest. then go through the flagged ones answering those you can find easiest in the book: if you have a decent general knowledge of the regs, you should now have answered about 45 out of the 60. then concentrate on the last 15 or so.
Thanks Tel, for your feedback.
I managed to scrape through with a 78% pass using all 2 hours not leaving much time to go through all my flagged questions.
Although very happy with passing I know I have a lot of work to do and will carry on navigating the regs as a source of revision.
Moving on to level 3 now, thanks again .
