Darkwood
But equally it seems strange to have dangling Henleys and the external meter when they could have got the meter kit for the Hager board...
That's assuming they knew such a thing was available. I've come across a few sparkys who have no idea what's available - and won't enquire. One example :
I was doing a network install for a client, and their contractor's sparks was doing the dado trunking - some rather nice Rehau stuff. I quite likes some of the details, like the way the lid for the bottom section was integral to the back, so formed a tray that cables would stay in by gravity rather than the usual faff trying to get the cables to stay put while you get the bottom cover on.
On one run I had to fit 24 network cables plus a 10 pair phone cable in, and he'd left me just the small section at the top - while using all the rest for 2xRFCs (4off 2.5mm T&E) and a 10mm bonding cable ? First thing he was 110% certain of was that only the mains can go in the middle/bottom section and network cables must go in the top section - otherwise they aren't isolated. Apparently, the plastic used in this trunking only insulated one way round ?
So I mentioned adding a divider to make it into 3 section trunking. "Doesn't exist" he stated with complete authority. Unfortunately, back then I still had a rather basic phone, and that together with a poor signal meant I couldn't look it up on site - to find that yes, they do in fact do a divider. Had I known I'd have just insisted on getting the divider, but not being able to say "yes it exists" there and then, there wasn't enough time without holding the whole job up.
Luckily there was an alternative route I could take the phone cable, it was just more work.
TBH, his workmanship was top notch, he was just an idiot who didn't understand how sectioned trunking works or what's available.
And for good measure, he said "it must be nice when someone else does all the hard work for you". In a rare case of self control (bear in mind I'm autistic and tend to say exactly what I'm thinking), I managed not to give him some rather painful instructions as to what he could do to himself.
This one is from a factory how many bodges!
Mm earth not long enough then!
Yes that is 1.5mm t&e into .75mm flex from a 30a ring final?
Same again mix of .75 and 1mm flex feeding multiple socket outlets all off 3036 30a fuse!
Pond spaghetti anyone, all outside in a dripping wet brick pillar no rcd all in 1.5 t&e no earth connected and the black flex was cut off in the garden still live inches from metal railings around the pond. Lethal! All this was also from 3036 30a fuse. Not any more all removed!
Sy
some diy disasters for your viewing pleasure.View attachment 63983
Sy
Good haul, remind me not to visit.
Got 9 bollards with a 0.08 N-E IR, all jointed underground with a flex coming through a concrete block. Mini digger coming tomorrow to break the lot of these out and to be re done in proper torpedos , or where possible both armoured brought into the new bollards. Installation less than 3 years old
yes that is a flex through a SWA gland with some tape to thicken it up.
Losing the will to live. 2 of us spent a few weeks at a commercial site disconnecting/removing unsafe wiring and testing repairing what could be saved when a company opened a new depot in an older unused site.
Half of the site was separated to be rented out, so we split the circuits on that side into a new DB via a sub meter, all thoroughly tested and inspected as quite a number of shoddy/unsafe diy alterations had been carried out by the previous owners, a shame as the original ~50 year old installation was installed to an exemplary standard. All defects were removed or faulty circuits disconnected for future repair if they were needed, and the area was safe to use by the new tenants.
Back there today, new tenants moved in a week or 2 ago, and we are being contracted by the landlord to repair the lighting in the workshop area of the rented side as this was now required, previously disconnected by us due to unsafe switching alterations that led to shared neutrals, circuits from different mcbs linked and other serious defects.
One of the parts disconnected was this:
When the wall was there there was a buried steel conduit going into and one going out of a socket. The wall was removed at some point, the conduits were cut at floor level and the singles were run buried direct in a chase to some wall sockets, the earth was by the metal back box touching the conduits. Of course there was now no earth continuity to any of the new sockets or the ongoing existing one after this alteration. There was enough sockets in the room from a fairly recent dado installation so these low level sockets were stripped out. I thought that would be the end of it.
I was wrong again. A new stud wall has been fitted and the wiring shown above has been joined onto some singles, (I think one of the cut off ring legs pulled out of the butchered conduit) up the stud wall to a new socket position. No CPC either. I just couldn't believe it, I couldn't fu****g believe it.
I don't know why I wasted my time removing the defects if they were going to be put back in even worse than before. I don't know where they planned to get the supply from as the entire circuit is chopped out at the other end.
Following on from yesterday’s post, look at the state of the cables buried ??. Wiska box is our new joints
I do love the storm glands they are great, much better than the cw ones. @ChrisElectrical88 do you not use the wiska earthing plates or piranha nuts for the swa glands? They too make life soo much easier!
I normally will use the Piranha nuts mate, wholesalers run out though and this was sort of dropped on me yesterday. Banjos are bolted on the outside rear of the Wiska box, bit rough, but all I could do with what was available
@ChrisElectrical88 sounds typical of the wholesalers at the moment. All you can do is the best with what's available!
@westward10 Quite possibly not on the 308 size box I think you are right that is why the earth plates were created, but I'm sure I've used earth nuts on either the wiska or wago box of one size or another and they worked in the past.
8K
Darkwood,
UKMeterman,
