J
John J
So I’ve recently started my level 3 course and I’m doing electrical system designs the one with the hotel extension and pool and cafe block I’ve done question 1 but stuck on all of question 2 some guidance would be appreciated thanks.
im doing the desgn project an finding it really difficult as I don't work in this back ground currently if any one wants to work on it together in emails or whats app give me a shout
Upvote 0
What you struggling on? Show us what you have and we'll offer some guidance.
Hi,
I don't currently have any pictures but I've drawn out on the hotel rooms how each would be wired for what the spec asks for. After reading through and breaking down the task sheet and looking around the forum I am beginning to understand this more taking it a bit at at time. I have less than 2 weeks so I was in a bit of a panic.
This is a question I do not understand
"Select, with the aid of manufacturers’ data, a suitable range of circuit protective devices for this
contract. Your selection should be based on the following
 Prospective short circuit currents
 Requirements for additional protection and special locations"
Upvote 0
Hi,
Ok, easy;
Select a suitable range of OCPDs generically (B6, C32 60898/61009s) them download the datasheets from a manufacturer of your choosing and add them to the assignment.
You should be able to calculate PFCs based on Uo and calculated Zs from estimated cable run sizes (assume you have Ze?)
As for special locations, here's a RCD Omission matrix from a different project to help (attached)
Upvote 0
this has been a helpful link as i am about to go to college to do my design week then my 2391-052, 52 practical assessment and exam the week after.
Upvote 0
Heyo lads, I’ve currently finished my Level 3 course and only have this Hotel Design project to hand in to complete it. I have 3 weeks to hand it in before I fail.
Due to COVID, job losses, family losses, I’ve only just managed to pick myself up and get round to it. Having finished my course a couple of months ago, I’m kind of stuck on a lot of questions and unsure where to go from here.
Mainly the drawings, unsure of the correct symbols to use, colours to use and where to place them.
If anyone could give some guidance on this project an help with a few questions it would he much appreciated, I already see some of the posts in the past can help so i’ll also use them.
Feel free to pm me or reply :)
thank you
Upvote 0
thank you
Throw th up here and we'll see what we can help with. A fair few questions have been asked in recent months about the hotel project so you might find your answer with a bit of scrolling and searching
Upvote 0
Hi guys, new to the forum. Can some one tell me how I can get access to the trainee forum? Everytime I click on the link Apply to Gain Access to Trainee-Only Forum, it stays on the same page.
I'm probably just being a bit thick!
Upvote 0
Easy method, use the adiabatic equation to find out the size
S = ✓ I^2 * t / k
I = the current required to operate the device
t = disconnection time required for the device
k = factor given for the cable selected - Typically 115
So for argument's sake, let's say we have a fault current of 320 (taken from your trip curves) a time of 0.1 (taken from your device operating times) and a K factor of 115 (taken from the tables following the trip times)
S = ✓ I^2 * t / k
S = ✓ 320^2 * 0.1 / 115
S = ✓ 102,400 * 0.1 / 115
S = ✓ 10,240 / 115
S = 101.19 / 115
S = 10.05
As there is no conductor with a CSA of 10.5, you select the next size up, in this case 16mm^2
The above is purely and illustration and values may not be accurate but it serves to show how to lay out the equation so that you can understand what is going on at each step.
Hope this helps
I'm with you all the way, apart from 101.19/115 equaling 10.05. I feel awful for pointing that out.
Sorry
Upvote 0
John J,
MrBob123,
Electrical Courses
