That looks like the socket was there first and they've introduced "period" style skirting boards and never thought of the heights.
it would have taken a sparks 45mins to move that socket up 3 inches , but no the builder butchers the skirting board instead ?
Can just hear the customer wailing “HOW MUCH” but you have only used £2 worth of cable.
Reactions: nicebutdim
Yes that is either 1mm or 1.5mm in the socket, no we won't put in a spur for a 2KW water heater
I have seen lots of sockets mounted upside down so the plugtop flex isn't squashed
With double sockets you can't really win as some wall-wart power units go up the way to avoid the too-low traditional mounting arrangements.
Singles you can do sideways to work, but really its a nasty legacy of (I presume) avoiding putting sockets in lath and plaster walls and using the board as at least a stable mounting base.
That almost makes more sense. For a certain definition of "sense".
But if the socket was there first, why so low? The skirting board is only about 20cm high.
Commercial Kitchens
Nightmare for dodgy electrical work.
Ring someone different everytime there's a breakdown or they need something changing, usually don't care who it is.
Is it just me but i don't see the problem there..
Yeah not too obvious from photo.
Singles in flexible conduit which crosses other conduit, and serious lack of saddles, also 3 routes to same place. 4 circuits running through EM light too.
Basically it couldn’t be tidied up without removing most of it and starting again.
Reactions: BiddeldyBwah
Ahh i see thanks for the heads up, always good to be pointed towards details that most miss.
Short of missing a cover, I can’t see much wrong. ?
A sheet full of C3’s but there may be other things lurking behind the cover.
Is that white flex connected?
You mean a shower on a 5A circuit?
I suppose it might just be a turbo pump with its own RCD...
I'm sure it is just "resting in the fuse box" and anything else would be an ecumenical matter :)
Reactions: timhoward
8K
Darkwood,
mainline,
