Unless you have a daughter that works for BT in the appropriate department!
'Friends in the right places' can resove many situations, but for most people that isn't an option. The point I was reinforcing is that it is basically impossible to have openreach resolve any issue with their network, unless a demonstrable fault exists that affects your own service.
Happily, I have a daughter who works in digital media and who has a knack of finding "direct" routes to those who matter. Finding a CEOs direct email and a threat of social media exposure means that many problems suddenly get attended to, but of course this should not be required.
Basically, it's blackmail!
Works really well...
Sub meter for supply to a shed.
Like my school reports
James really needs to pay attention and work harder.
It would have been safer if he had put L and N feed in the centre connections :)
They used some blue tape though. Gotta give them credit for that at least.
Ignoring the exposed copper. Isn’t that crossed polarity? Meters I’ve looked at the lives were the two outer and the neutral the 2 inner connections.
in this case I think "work smarter not harder" would have been even more effective - no more work to do it properly the first time, after all....
Yes, normally L in, N in, N out, L out
Maybe doing it this way, they got the meter to run backwards! 😄
I usually got something like:
Julie set's herself an extremely low standard.
And often fails to even achieve that!!!
  • Funny
Reactions: loz2754 and DPG
Mine always said "Must try harder", but it brought back some memories, my French teacher was Bridget Osman and her initials always brought a smile to my face on the school report.
  • Funny
Reactions: Jim_e_Jib
I had the same thing expressed the other way around. I had a cracking Geography report in the 5th year which I must find. It said something like:
“I am obliged by school policy to report in positive terms. I can therefore honestly say Tim aims at nothing and hits it every single time. I’m also obliged by school policy to point out an area of improvement. Tim is increasingly adept at starting vehicles when staff have mislaid their keys. I have been grateful for this service more than once. We must accept that Tim’s skills are not suited to the subject I teach. I wish Tim well and believe he will go far, maybe in a vehicle he actually owns one day…”
What's wrong - it has to be a first class job given that they've used a Wiska box 😎
Shame the wires are outside the box!
Bedtime read
Was At a property to do EICR looking to rent out for first time and, certainly in my top 10 shake of the heads category.. will put all pics on a slide for 2391 training - spot the mistakes..
I looked at consumer unit... owner had issue, and got someone in via insurance, recommended an 'electrician' to change the board, same guy also apparently was a kitchen fitter.. that's another story (yeah removed cooker socket left cable connected , hidden sockets no spur switches etc...)
Anyway was a BG split RCD with 6 breakers - only 4 used (4 light circuits in one breaker).
Also two separate 5 way RCD BG boxes for 2 showers, 6mm (see pic few broken strand so nearer 4mm) feed to these direct via the isolator switch* straight from the national grid see pic - - with 50Amp MCB's using 10mm to the showers. Found despite connected only one electric shower fitted, other cable buried in wall still live.. - so disconnected unused and will move / upgrade other to 10mm.
Apparently also told customer that was biggest board - honestly I would've fitted 15 way RCBO in the space and left room for future eg EV etc..
Then neutral disconnected this turned out to be ring main for. upstairs and should be on LHS so only 1 Neutral connected customer told me there had been odd tripping.
And to top it off - no protection used at any entries, meter tails thru separate entries..
Will stick up the fixed photos.
Rough as a badgers…..
Last photo….. is that the bus bar shield?
It most definitely is the bus bar cover on top of the CU... I know because that's how I found the one I took out of the board I was working on yesterday... when I'd put the cover back on :D
Hi 🤣apologies yeah was shield on top of the box when I got there
8K
Darkwood,
mainline,
