I know Quickwire are relative newcomers, and there are quite a few other easy-style connectors out there, but I do think Quickwire will be the new "Wago" for lighting. I also know that many think the cost is quite high, but the time-savings are considerable.
I love new technology like this. Same as I embraced Quinetic many years ago, when the time savings and lack of raggling(chasing) plastering and painting made it a new solution for many cases.
Wireless smoke alarms with radio modules to interlink, and a 10 year life shows the same type of savings...no wiring, chasing, redecoration...might seem expensive, but compared with the alternative, money well spent.
No race to the bottom, guys and girls...spec the good, clever modern stuff...do the job fast and well, no call-backs...and happy clients.
Just my random ramblings...but remember when we had no LED head-torches or cordless drills etc? Now we wouldn't work without them.
The cheapskate boys will always get work, but the quality electricians will always get quality work, and that is what matters in the long term.
I'd place quickwire in a different category to wireless interlinks. While both offer time saving solutions, at a price, there's no prospect of wireless failure with their connectors.
Wireless switching and smoke detector interconnection is something I'd only consider when adding to an existing installation, where it saves considerable time and upheaval, and there's no question that this may often be the better option for customers. For new installations I'm firmly of the opinion that everthing should be hardwired.
I'm not sure about the t connectors but I thought that too about the switch and load. If you look there's little holes in the sides I believe you can get a probe in there. I'll try it later but would be pretty sure thats what it's for.
That thought struck me last night, but I didn't have one to hand. Looking at images online I could only see holes on either side, so wonder if that's what they really are and, if so, where CPC can be accessed.
Edit: seems I should have looked elsewhere as this was answered in Quickwire's FAQ section, back in 2017. All of their junctions have test points.
Here's a picture if it helps
Reactions: nicebutdim
Is that one you installed? It looks rough, copper exposed on the L & N, and all looks a bit tight for space.
I don't like those white connectors, always remind me of Chinese carp.
I guess they just couldn’t be arse here and made a token effort with a single conduit saddle.
Reminds me of a short video from @dseselectric of a car charger install.
I'd hoped to post in reply, but the bugger seems to have taken it down.
Edit: it's still there - check out this masterpiece..
Not being funny, but who in their right mind would agree to pay for that???
Truly shocking!
Yeah I saw that. Made me chuckle as I’ve seen a few ---- EV charge point installs that I get asked to rectify.
Truly shocking!
I’ve had to sort a few, including one where they had TT’d it and connected it back to the PME!
I wouldn’t mind but the charge point had built in PFP. 🤦🏼‍♂️
Or even vertically by the side of the RWP and horizontally under the widow, there may not be enough cable, but nothing a nice neat 45deg angle under the window would not cure and look much neater.
A few pictures from my phone of past jobs
Just for clarity, the 3 brown 16mm singles taped up coming out of the trunking are fed from the crappy distributuion board pictured,supplied from on the top right Triple pole breaker, 63A, three phase 400V 😱, trunking was not earthed, went to another moody three phase board the other side of the warehouse about 40 meters away, pretty much taped up their entire length, must have took most of the day taping them all together, they were joined with 30A connector blocks about 4 times throughout the run
Did you get the ‘it works ok 🤷🏼‍♂️’ response when you pointed it out? 😂
Definatly a contender for the longest ever EICR observations list!
And this weeks award for the most ridiculously placed consumer unit and grouted in shower isolation switch goes to…
The hidden in the top corner of a built in wardrobe. 🙄
I do wonder what some people think when they do stuff like this.
Seems like someone mislaid some of the linking kit.
Reactions: Jim_e_Jib
8K
Darkwood,
mainline,
