Clearly wrong! It is the black that we are told should be G/Y over-sleeved!Erm, I think someone got the wrong idea when interpreting the advice with single phase use of swa cores.
(sarcasm, in case anyone takes me seriously)
Doesn't matter at all provided it is correctly identified BS7671 does not suggest which one is x, y or z.Out of interest (to a trainee), what is accepted practice when using phase colours in a single phase installation?
When using 3 core for lighting, clearly it's grey sleeved as neutral and black sleeved as switched live, but what about a submain in SWA?
The only prohibited over-sleeving is the use of G/Y cable. That used to be the case for singles but it was ambiguous if it was allowed for multi-core cables, but now with AM2 it has been clarified that you never use G/Y cable for anything other than a CPC.I couldn't find a regulation that prohibited the use of any correctly identified conductor, but I don't always find the reg I'm looking for on the first attempt.
No it was the fact they already had the 3 phase line colours there, but over-sleeved one of the lines as CPC and failed to over-sleeve the neutral when used as a line.The previous posts confused me and had me thinking the issue was which conductor had been used as earth, rather than the fact that blue was used as L3.
There is this diagram in the regs that shows how the colours have changed… (not original, I had to Google this)
It’s there in black and white…. Or brown black grey…. Whatever.
In the case of 3ph, no neutral… then the blue, over sleeved in g/y (at both ends) is the only solution… or use 5 core that has a g/y
That was the reason for my sarcasm. The "black should always be over-sleeved as CPC" and not used as neutral brigade.People will give you some daft reasons for this, 'de-neutralising' is one nonsense phrase often bandied around, but there is no rule or regulation for this.
Easily fixed with a metal box and a couple of inches of 2 X 1. That's how we retro fitted boxes into a cavity wall before these 'fast fix' abominations came into existence.This tickled me. I was called because the original guy abandoned the job and has made up endless excuses not to return.
You can imagine it unfold - aargh a joist. Never mind I’ve got a genius idea. Just put the the front on. Ah……
I suppose the other option if using swa single phase is to buy it the with the brown, blue, green/yellow colours.I like the convention that uses grey as neutral, but simply because the alternative means picking a conductor at random from one job to the next. Where possible, consistency is my friend.
I keep asking my boss to buy single phase three core but it almost always arrives three phase colours.I suppose the other option if using swa single phase is to buy it the with the brown, blue, green/yellow colours.
Wonder how he intended to screw the socket face down.This tickled me. I was called because the original guy abandoned the job and has made up endless excuses not to return.
I’m assuming that is why he stopped and ran.Wonder how he intended to screw the socket face down.
Don't bother with sleeving, just paint itI keep asking my boss to buy single phase three core but it almost always arrives three phase colours.
I don't have time to send it back so have to have Good stock of sleaves
I remember a few years ago after dropping a light switch and seeing the black S/L with about 2 inches of red on the end and thinking that looks very neat as the sleeve was the same diameter as the black.Don't bother with sleeving, just paint it![]()
