Darkwood
We are currently re-wiring a run down house, just your average 3 bed end terrace. Everything inside it electrically pointed to it being some sort of old commercial business, EM lights dotted about for one. but according to the new owner it wasn't, he said an old bloke lived there that was a bit mad, nothing shows up on Streeview either showing it anything but a house. I could have taken many more photos of things but this is the sort of stuff he got up to apparently.
That one is my favourite, screwed to the underneath of a floorboard, fed in alarm cable so maybe some sort of booby trap.
Secuirty light switching
Cables everywhere, these were for the CCTV
Backdoor
All that was left of the shed, it was full of electronic stuff apparently, would have loved to have a look around it but it was gone before we turned up.
And lastly a bit of switch wiring
Looks normal but it was years old and wired about 30 years ago or more, those cables are twin and earths, not 3 cores with the grey cut out. Where the hell did he get black and brown cable from?
That circular wooden plinth would have been the base for an old toggle switch. Has no holes drilled for the wires so must be a joint box, never seen that before.
Maybe 'whoever' should have changed that beauty when they carried out the rewire........60 or 70 years ago. 😉
Or perhaps it's just been kept for show.
If you go to Beamish Museum, in the 1900s town, in the cellar of the bank, you'll find this.
I do wonder if it's genuine, or just random bits tgrown in for show.
At our church we have "modern" wiring - imperial T&E (or T no E on the lights), but they used the old switches where visible to fit in with the aesthetics. Not that there would have been any lecky when it was built 200 years ago, that only arrived in the 70s.
Are they actually prohibited even if fitted when they were allowed, or prohibited to be fitted ?
This site says they aren't retrospectively banned, so as a matter of ISITEE, it's not a fail to see one - even if it wasn't legally fitted in the first place.
Another site backs this up, but they "recommend" they be replaced.
Last ISITEE code of practice I believe recommended that plugs with non sleeved pins were swapped, but it was not mandatory to do this. Not sure about the current revision 5 of the COP though as I don't have it.
Nope..... That is not how you feed power to the garage mate.
Posted this up ages ago but it still make me chuckle.
OMG Paul, great photo.
Leaving the top/left hole open to IP is ridicules… there’s 4xFixing positions.! So USE them.
Over use of open grommets is a Waste of products.
The only thing missing is a ‘Hair Clip’ or 6” nail.
Luv these pics to show my apprentices.
Maybe your apprentices will notice the actual wiring connections.
Like this, found last week...?
A little depressing when you see stuff posted on here as antiques, that you've fitted as new.
Later versions of these switches has similar switch mechanisms inside to modern plate switches, but earlier versions had a totally different underslung over centre mechanism that gave a fast make and fast break, which was suitable for switching DC as well as AC.
New extension and old house refurbished. Builder moved service head himself and made the access hatch sooo small everything is inaccessible. Electrical work was done by a sparky 😳 Cable outside on the roofing tin was found to be live and just taped up.
Builders had a melt because the works been callled out!
OK I will bite, what are those grey oblong terminal blocks above the RCBO's, not part of them as they don't line up, been out of the game for a while, I know the orange thing on the right, but those blocks are a new one on me. (surge protection maybe ?)
8K
Darkwood,
mainline,
