Rockingit
Mentor
Supporter
May 25, 2011
6,161
7,152
10,256,798
Somerset
Story short, I could really use 4 lengths / 12m of bog standard 20mm galv conduit c/w couplers for first thing on Tuesday, in York. And as it’s now Saturday and Monday is the bank holiday I’m short on options from wholesalers. Anybody in the area got any I can buy/scrounge/beer tokens?! Doesn’t even need to be new, just clean. I’m in York from Monday, which is also antisocial.
R.
I’ve got about a metre in the back of the van, but you would have to come up the A1 to get it.
No York wholesaler can deliver it first thing Tuesday for you??
Screwfix sell galv conduit in 3m lengths, threaded at one end, plus couplers, are open bank holiday Monday, and you'd only have to visit maybe 3 stores in the York area to get enough for what you need. This all assumes you have the means to thread the other end!
Reactions: timhoward and DPG
Order before 6pm today and it will be delivered to the screwfix store you select tomorrow so no need to visit loads of stores
Reactions: pc1966
Toolstation also sell it, if I recall correctly it's threaded both ends with a coupler on one end.
He’s gone quiet….
Maybe the suggestion of going to screwfix has put him into shock??
Surely most wholesalers are going to have 20mm galv conduit on the shelf?
As an aside, I'm wondering if it's supplied in 3m lengths in GB? Screwfix carry odd lengths, but OP also mentioned 4 lengths being 12m. Over here glav conduit comes in 3.75m lengths.
It depends which wholesaler you go to some have 3.75m lengths in stock and some have 3m lengths in stock and some have both in stock so it is a bit of a lottery
The likes of Screwfix and Toolstation only have 3m lengths
  • Informative
Reactions: nicebutdim
He’s gone quiet….
Hehe. It was actually a win for screwfix - 3m lengths of 25mm c/w coupler and threaded both ends, picked some up in Liverpool yesterday. And it's for non electrical use..... when in theatres you see huge big scenery drapes flying in and out, at the very bottom of them is a sewn pocket instead of a hem, into which goes a solid length of conduit or similar tube to keep it all taught and even. This is sort of similar use for a rock backdrop.
  • Winner
Reactions: SparkyChick
you mean..... it could have been anything? not just conduit?
would copper water pipe have worked? broom handles? or even fork handles???
(oh no... don't start that again!) 🤪
Not heavy enough, it needs to have a bit of weight to it to keep the bottom of the cloth straight(ish) And it needs to join together easily so you can get it out again take it apart.
Reactions: SJD
Increasingly it is supplied in 3m lengths, my wholesaler made some.excuse about fitting in their vans easier when they changed from 3.75 to 3 a few years ago.
  • Informative
Yes I know. But I was just trying to get round to the fork handles joke…
I'd be inclined to agree. 3.75 is fine in larger vans, but has to go on the roof of anything with a shorter wheelbase. I'd be quite happy to see 3m lengths, although that would mean extra bundles on larger installation jobs.
How about rebar with maybe some pvc tube used to push fit join it.
The sewn hem is likely not that large, so you want something that slides in & out easily with minimal steps that might snag. Equally it must withstand a lot of use bringing the cloth in & out possibly many times during performances, and possibly even a bit of bending if the bar the cloth is hung from is not quite level. We use 20mm galv. conduit, and screw/unscrew each section as it it pushed/pulled in/out when hanging/striking the cloth. Probably too much detail for an Electrical forum!
Rockingit
Mentor
Supporter
Somerset
YORK - need a favour!
Rockingit,
littlespark,
