As the title suggests
In respect to the debate in this thread http://www.electriciansforums.net/e...electrical-forum/33420-neutrals-switches.html
I've decided to launch a poll to gage response from the forum.
GOOD / ACCEPTABLE - If you think Neutrals at switches is OK
BAD
/ UNACCEPTABLE- If you think Neutrals at switches is NOT OK / WRONG
UNDECIDED - If you have no preference or are fence sitting (like me)
The poll is timed for 7 days...... So get polling
GOOD - If you think Neutrals at switches is OK
BAD
Can you not use the word 'acceptable' rather than good?
I think it's acceptable but I wouldn't describe it as being 'good'
Good point IQ...
You can't change the poll once it's posted..... Apparently :(
I did toy with various levels of acceptability but opted for the straight Yes / No as it was becoming complicated.
Acceptable would be better. Anyway I've voted, it will be interesting to see the outcome.
Well I'm definately bad .........but there again ...........no definately bad ................but on the other hand it could .................NO I'm decided it's definately .....................yes I see your point
Oh drat I must be a fence sitter
Malc, and RWJ ur arses must be sore with all that fence sitting lol
same for me, perfectly acceptable if required although i wouldn't necessarily go out of my way to do it like that
I think it should have been more a case of "where do you loop to - rose, switch or either?"
I do whatever depending on the circumstances - I wouldn't go out of my way to do either.
So on that basis my first vote is 'undecided', second vote 'OK', third vote 'not OK'.
Oh an AV man lololololololo
You also forgot the singles method! - Not meaning to open up any more worms!
You only have to look at some of the pictures provided in the other thread to see that its bad practise putting so many cables into such a small backbox. Using a switch as a junction box is terrible. The only people to have a switch that encorporates this is hager (as far as I know), so it can't be that common otherwise all the manufacturers would have this encorporated.
Put a deep enough box in and I can see nothing wrong with it.
However, if all you are doing is wiring pendants, then I can't really see the point in wiring to the switch first, however, if you want to keep the number of cables down at the light position (say for a fancy light) then its a good way to wire it.
Pros and Cons to both wiring method's, which is why an experienced sparky can decide which method is best before undertaking the wiring!
Just to throw a spanner in the works, who still wires a feed to a joint box in the roof space and wires all switches/lights from that???
There is nothing wrong with it ... where it's appropriate. It's like most things you would do it where warranted. For wall lights, I wouldn't hesitate.
