S
Smokey85
Hello AllI am looking for some advice, my girlfriends CU needs to be replaced and removed.She had two extra rooms fitted to the apartment (which converted an old hallway into part bathroom), and her electrics have been left in a sorry state. Currently choc-blocked to death, even on the CU.Its currently in a position which does not meet the 17th Edition, its about 20cm from a sink (seperated by a MDF panel), and 10cm from an immersion heater which only has one element, (the top is missing, and there's no sacrifical anode).Its a little like this:Meter Service Fuse E7 (Outside in meter box) > Very Old WireFuse Box (actually in bathroom with no dead-front) > 60A Cable with ChocBlock (cable comes out behind fusebox and into immersion heater cupboard, a chocbloc then attaches it to the cu ) > 16th Edition CU (10cm next to immersion heater in cupboard / 20cm away from Sink seperated by MDF panel) > ServicesI've bought a new CU 17th Edition Compliant (Wylex Dual RCD with 7MCBs and 1 RCBO).There should be no problem fitting it to the top of the cupboard corner, and I plan once supplies are isolated to literrally feed the cabling straight from the Meter to the new CU (to get rid off the old CU and Ancient deathtrap FuseBox). The problem is the service wiring, it simply is not long enough to reach the extra meter of the top corner of the cupboard.Is it a requirement to place all new wiring to the cooker, lighting, sockets etc... Or would it be possible to use service connector blocks or something else which can withstand the cable current(open to suggestions) for the 1m more cable I need.On compleation we then need a PartP Sparky to certify the installation, so we can rent the place out.Current Estimates for the work have been very varied £700, £750, £1200, £1750... So is it possible to extend cable or will it need re-wiring? The later sums of money are a bit to much, and the first two (not impressed with abilities - they are not options).Any thoughts?Many thanksSmokey
