Monkey read your regs a 20a dp switch leading to a spur is not following the bible it has to be fused down to 13a either with a 13a sf or a 20a grid and 13a fuse so want it or not you still have fuses above the work top so seems crazy to have a second fuse under the work top I have a funny feeling we may see a more definite direction of this in the regs soon to clarify it better as to what is expected until then we do what we feel is right
Please can you quote the specific Reg so we can all take a look?
You can't have a fused spur above the work top and a socket out let below for say a washing machine, where's your discrimination between fuses, it has to be a 20amp DP switch.
Its NOT rubbish!! It happened end of!
It is Rubbish, absolute rubbish!! If you as an electrician were so easily fobbed off with that kind of crap, then more fool you!!
This has come up on here so many times now. Let's get this one straight once and for all!! The only reason manufactures fit a plug to appliances up to a certain rating, is to do with EU regulations, in that manufacturers must fit a plug to appliances that is suitable for the country of final destination. It has nothing to do with any end user warranty!!
A manufacturer cannot and will not invalidate ANY appliance warranty, if the appliance is connected to the supply by a means that is recognised as compliant by BS7671, or indeed any other countries compliant methods (the same models are available throughout the EU and the plug tops won't incorporate a fuse!!).
What your talking about, are these warranty service agents that some manufacturers use, that think they are above commercial/consumer law. They often try it on with the general public but, i can assure you they have no legal footing to do so., It's normally based on the fact that the service engineer sent round to sort out a problem with an appliance, can't be arsed with disconnecting say a FCU or CCU. So they try the warranty invalidation angle/stance!! Further, i've personally never seen a manufacturers warranty that stipulates removal of a plug top will invalidate said warranty. If it did, it would contravein UK consumers rights, and could be totally ignored anyway!! lol!! Maybe different if the end connection was DIY hack job, and left in a dangerous condition. Even then, once restored to a compliant connection the warranty would continue!!!
There was a member here who's wife is a solicitor, and confirmed that manufacturers have no grounds to invalidate any appliance warranty purely on the grounds of the removal of a moulded (or otherwise) plug top. The appliance has to be fit for purpose, so any component that fails (ie element, switch, pipe, pump etc) during any warranty period issued by a manufacturer must be rectified, or replaced....
It wasn't my boiler to get fobbed off with, i only heard after the fact and i've never chopped a plug top off since, i've never looked into the legal side of the warranties these manufacturers offer to see if chopping a plug off will invalidate said warranty but i'd just rather not do it anyway for reasons i put in previous posts, everyone has there own way of doing things and i shall keep doing things my way and if the need comes one day to lop off a moulded plug top i will now do so safe in the knowledge you said it was ok and it WILL NOT invalidate any warranty manufacturers or otherwise
It's not me saying it, it's legally the UK's consumer rights legislation etc, that is doing that!! I'm just informing you that your statement on removing a plug top from an appliance and connecting that appliance via a complying means of connection, to the mains supply (FCU/CCU etc) invalidates a warranty is Wrong!!
Again, don't take my word for it, check it out for yourself either via a solicitor or a consumer group/agency!!...
