1sammaskell
yes i would do this on a totally different circuit, would do cable calcs for appliances also to make sure it is suitable.
what could be easier a supply to a grid, link your lives and then terminate into an un switched socket, simple all switching done in the same place!
You wire a 20a double pole to each under counter socket for each appliance off the ring, marked up on switch what they're for, i don't see why people on this thread have a problem with this? I also wouldn't go cutting the plugs off appliances to wire them straight in as it will invalidate the warranty
First. I'll warn you, I'm half cut, so if admin take the huff, then oh well, I'll deal with that tomorrow !
Right, tell me, the posters above me, are any of you sparks ? Running a spur, through a 20a DP switch UNFUSED ! I've done something similar to this once, when I was an apprentice, even then I had the (half) sense to use a 32a dp switch !
Next, running a 6mm for a grid bank, again with no fuses, either means a low load with about a 150m run, or you haven't a clue ! If it's the second one, do yourself a favour, get yourself a QUALIFIED sparkie in !
IT DOES AND IT WILL!! I've had first hand experience of this by chopping a moulded plug off a boiler, wiring it into an fcu and then when it broke it wasn't covered under warranty cos the plug was cut off!!!IT WILL NOT INVALIDATE ANY WARRANTY, ...Jesus how many more times!!!
