IT DOES AND IT WILL!! I've had first hand experience of this by chopping a moulded plug off a boiler, wiring it into an fcu and then when it broke it wasn't covered under warranty cos the plug was cut off!!!
Absolute Rubbish!! You actually let them get away with that gem did you?? Any connection to the mains supply that complies with BS7671 cannot invalidate a warranty....
I agree. The service agents will not touch it.
Then more fool you, for letting the service agent fob you off. Cutting a moulded plug off an appliance (Any Appliance) does NOT invalidate the warranty ...End Of!!! Check with your solicitor if you don't believe me!!!
Come on get real, if the plug gets damaged then of course the company will send one of its own engineers to change it as otherwise the warranty will be invalid :rolleyes2:
Think about it chaps,you can demonstrate your competence to the assessor or 2391 examiner for dozens of tasks but you fold justifying it to a tech/sales phone jockey at ACME fridge-makers ltd? Use the force...
If you cant justify your actions to a call center then I think you seriously need to consider a new career if you are a electrician.
Being a qualified spark gives us our own rights and if you read the documentation with your appliances most state they are not covered of plugs are removed but no court would ever let them off with cancelling the gaurentee if the work is done by a qualified person. As for the fact I had not actually seen the grid type fuse holder does not mean I am any less of an electrician so don't judge me on that and the reason I personally use 20A flex connectors behind the appliances and not an unswitched socked is because I hate the idea of having to remove the appliance when the fuse in the plug blows as for plugs in adjacent cupboards unless your going to place them at the front of the cupboard is it really that easy to access it to change the fuse there either its a personal preference only and is still ok with the regs
Its NOT rubbish!! It happened end of! Anyway beings as its just a simple matter of fitting a socket under the counter supplied by a 20a dp switch above its just easier to leave the plug on and that way if someone wants to change a faulty appliance they just have to unplug it and plug a new one in instead of getting an electrician in for such a simple task! Or if it breaks and a service engineer comes out to fix it and see's the plug has been lopped and uses it as a reason to say the warranty is invalid because of it, it will cause the customer grief, you grief and lead to speaking to solicitors as you say to get it sorted!! Also if someone goes out and spends £400 on a new appliance and you just come round and lop the plug off in front of them how do you think they'd feel? I agree for convenience it would be easier if the fuse blew to have it above the worktop to change but be honest how often does a fuse blow in these things unless theres a problem with it anyway? I've been doing it my way for years, its been like it in every house i've lived in and i think fused spurs everywhere above the worktop looks so ugly in a kitchen, its looks much better to use grid 20a switch or normal 20a switches with the appliance name on the switch, i'll keep to doing it this way i think!
Monkey read your regs a 20a dp switch leading to a spur is not following the bible it has to be fused down to 13a either with a 13a sf or a 20a grid and 13a fuse so want it or not you still have fuses above the work top so seems crazy to have a second fuse under the work top I have a funny feeling we may see a more definite direction of this in the regs soon to clarify it better as to what is expected until then we do what we feel is right
Having a 20A dp switch is no different to just having a socket spurred off the ring surely? Its not going to be pulling 20 amps down it as its one 13a socket, where in the regs does it say that? And you've contradicted yourself because you've put that you can't have a 20a dp switch leading to a spur but you can have a 20a grid switch so which is it?
When was the last time anyone had a fuse blow on an appliance, replaced the fuse and it carried on working? The machine blew the fuse for a reason so chances are it has had its day or there is a serious fault requiring an engineer of some sort.
Nonsense, if a fuse blows you replace it with one of a higher rating, then the thing works again and everyone is happy.
I just cannot see a problem having a single socket below the worktop and the fuse in the plug top TBH, whats all the fuss about with doing this then? pretty normal practise in 99.999999999% of the kitchens in this country
I am totally confused by all of this, what seems to be the argument here is there is a 20 amp double pole switch in a grid feeding a socket below the worktop feeding lets say a dishwasher, inbetween this link a 20 amp switch added above the worktop as well? some think this switch between the socket and grid needs to be a 13 amp spur? or that a 13 amp fuse added in the grid? or that the plug top is removed and a spur added below the unit as well, what a bloody mess, why not add a switch next to the dist board, next to the grid and in the lounge as well so we can have 5 means of isolation and fuses and not one LMAO. regs huh, sometimes common sence and good practice is the way to do things, just how many 13 amp switches do we need here, whats wrong with having the grid on it's own 20 amp ring main and legs out to the socket or spur below the unit only and no Switch above the unit? if there is a requirement to have a switch above the unit then do not have the grid as well, too many switches and too messy IMO.
When i mean grid switches i just mean so say you have a dishwasher and a washing machine under one counter, then have a gridplate with a 20a dp switch module for each so 2 in total in a 1G plate and then under another counter a fridge and a freezer seperate then the same again 2 switches in a 1G plate one for each socket, all spurred off the ring, keeps it very neat
you have to take each kitchen on its own merit and design.
you can use a switched spur above counter and flex outlet, appliance protected by fuse. Esentially used for intergrated appliances
You can use a grid switch to isolate single unswitched socket. moulded plug protects appliance.esentially used on non intergrated appliances. Or place socket in adjacent unit and feed plug through side of cabinet.
You can run a grid switch on on seperate circuit. 20A radial
you can run a grid switch on the kitchen ring and use the grid with fuse holders.
Like i said its all down to customers need and ease of access for safe isolation. As a further note to a post above about Barretts spec, i know what he means, persimmons (charles church), wimpey taylor, bellway, etc etc all use different types above as standard, so if you get one of there homes you will see these.
I hope this simplifies things here, its all in the design.
cheers
