Discuss Strange fault in the UK Electrical Forum area at ElectriciansForums.net
It's just a switch mate and doesn't trip.
Internal mechanism might be shot though causing it to open but you would tell that when closing it surely !
Maybe someone thinks that green means "go".
There is no way I can think of that all the MCB's, plus the main switch would end up in the off position unless..
a) Someone is messing
b) There is a ghost
You have done all that you possibly can, so maybe suggest to the homeowner that they get someone else to come and have a look at it.
I know you won't want to walk away from the problem, but I really can't see how it is anything other than human interferance.
I know mate it feels fine when closing, def think someones messing around.
I would disconnect the main switch inside the consumer(without telling them) and just have the rcd covering the board....I'm guessing there's another isolator on the tails?
If it opens again then someone is extracting the proverbial mate lol
edit
and put another mcb in, but not wired up, and see if that trips lol
^^^ was going to say pretty much the same thing....short out the switch out of circuit, you're not leaving the install any less 'protected' temporarily, see what happens. If it only happens night, might be someone sleep walking?? Kids do do this!
Get a a camera in there. Its the only way youre gonna prove exactly what's going on and who's doing what. It's also going to save you visiting every day. Unless you want to visit every day of course ;-) daz
Cheers Rockingit, It's been happening between 5pm and 10pm at night which I think is when the daughter goes to bed, and it never happens when their not in.
So definatley points to her !
Reply to Strange fault in the UK Electrical Forum area at ElectriciansForums.net
I sorted the fault fairly quickly as it happens but only because I'd come across it once before and at the time a few people said it couldn't...
A silly fault in a circuit only 4m long is currently eluding me! This is ECIR remedials of a landlords supply in a block of flats. Circuit 2 =...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
