Currently reading:
Which clamp meter for earth leakage AND continuity/voltage?
Discuss Which clamp meter for earth leakage AND continuity/voltage? in the Electrical Tools and Products area at ElectriciansForums.net
HappyHippyDad
Supporter
Hello all,
I've been looking for a while for a clamp meter that includes earth leakage, along with resistance and voltage. Some of the earth leakage meters that seem to do a reasonable job and are fair priced dont make it clear if they also test voltage/resistance which i would want as well (hopefully for around the £100 mark??). These are 2 of the ones that I have seen, the Dilog having fairly good reviews:
Dilog DL6507
TM-EL9809
Any suggestions for which one does the lot (i.e earth leakage/continuity/voltage) at a fair price?
Cheers all...
Dilog DL6507. Buy online or call
looking at this, the meter appears to have the 2 4mm sockets at the bottom, so it would seem that it can also be used for testing for voltage and continuity. as in a simple multimeter. looks a good buy.
well..i have a leakage clamp....but use a beckmann clamp that plugs into one of my MFTs...
i also use an industrial multimeter for voltage etc...
Thats kind of what I thought Telectrix, if its got the sockets at the bottom it does continuity/voltage - I think?? But I couldn't see on the actual meter a voltage or ohm sign!
should do....
the reason a multimeter would have a current clamp on it is so you can take current readings without interrupting the supply...
think meters in series...and meters in parrallel....
I have the Dilog, and apart from screwy readings which turned out to be the battery getting low, I'm quite happy with it. I always use my MFT for anything except clamping though, as it's calibrated.
Thanks Guitarist,
So can it measure continuity and voltage?
Cheers.
Thanks Guitarist,
Cheers.
Yes, and there's even a zero function for the continuity, along with a set of leads.
As I said though, I have never used it for that when I have a calibrated MFT with me all the time.
Also, be sure to make yourself a "clamping" lead up for measuring current drawn by any appliance.
Hippy:
a member in here has a chauvin arnoux clamp for sale...this will also do continuity and AC/DC voltage, AC/DC current, frequency etc...
its brand new never been opened..
now, if you know anything about test gear then you will know that chauvin arnoux are the dogs balls of current clamps...
cheers, mate. be interested if it's got low enough resolution for leakage measurements. mine only goes down to 1mA.
Hippy:
Thanks Glenn,
It would be good to take a look at it. Cant find it advertised anywhere though?
Thanks Glenn,
no...theres various different models..
chauvin arnoux are just about the largest maker of current clamps going...its what they have specialised in for years..
send paul a PM...see if its suitable...
the alternative is the amecal leakage clamp...about £40..then just get yourself a decent multimeter...
like i says, i have the amecal leakage clamp....and its OK...the metrel one is identical...but comes in at about £79...
sometimes its better to have seperate instruments....you cant have enough test gear in my opp...
Hello all,
Dilog DL6507
TM-EL9809
Cheers all...
Think you'll find these two models are the same meter just branded differently...
They have the same specifications too. I more than happy with the Dilog, it has excellent resolutions too, that are comparable with leakage testers more than twice the price!!
Not exactly very good on the resolution stakes is it, and probably why it's only 45 quid!! lol!!
As the old saying goes, buy cheap, buy twice!! And after all the praise for the Dilog and TM unit you recieved too!! lol!!
I'm going for Dilog, cheers for the advice guys.
Does anyone else get excited about buying tools!!? :teeth_smile:
course we do. it's like a woman buying shoes, only we don't visit 200 shops then go back to the 1st shop to buy what we should have done 3 hours before.
I dont know Telectrix, i've spent quite a bit of time faffing around looking at clamp meters now. Still not entirely sure I need the thing..... but its so pretty and shiny!
It's one of those tools which you will hardly ever use, but when you do need it, it's priceless.
Bet you spend an hour when you get it testing how much current everything in your house draws....Don't forget to make up your appliance test lead before the Dilog arrives though. :)
I'd disagree with that statement, with the amount of RCD's being used these days for just about everything!!
Far better and easier to fault find with, especially when tracing leakage faults than with an MFT ramp test.
I think every electrician should have one in their testing kit!! ...So long as they know how to use them!! ..lol!!
Let me put it this way my friend... I've had to use mine 3 times in the last year, working solely on domestic installs. To me, that's hardly ever, compared to the other tools I use. I'm sure though that some people would use it more, depending on the jobs they do. :)
You summed it all up in just that one statement ''but when you do need it, it's priceless.''as to why every electrician should have a leakage amp clamp as part of their testing kit!!
But to be of any real use, it needs a consistant good resolution value, which 45 quid isn't going to give you!! When for around £100, you get everything you need!! It's then money well spent for any electrician whether you use it 3, 30, or 300 times a year!! lol!!
Agree.
Reply to Which clamp meter for earth leakage AND continuity/voltage? in the Electrical Tools and Products area at ElectriciansForums.net
