The TEK775 has a resolution of 100microamps (ie 0.1 mA) on the 200mA range with a 5%+/- accuracy. I didnt think this was bad for general domestic use but I would be happy to be overruled by our more experienced members.. I guess like anything else, you get what you pay for.. if you need greater accuracy then you pay more.
is lazy and can see nice and easy return path back to Earth. In the Event the main Earth and Bonding being removed within the installation, the Circulating Earth Currents will simply sod off somewhere else with a better path to Earth (hence the need for "Protective Multiple Earthing" for TNC-S, to ensure there's always and "easy path" for these currents and broken DNO Neutral etc).
