Can it do all the tests the one I linked too does?
i only scan scan read the other spec but yes I think so. The issue, if you have a metrel, is whether your mft supports it as the easi switch needs the mft to work.
fyi I have the euro test at
hope this helps
Cheers, I have the euro test 3002, it doesn't say it works with that model so may ring forum sponsor test meter if I decide to purchase one as it is a little expensive.
I have one like this:
I have made a promise to myself that one day I'll find out what it's for.
Isn't it for looking pretty next to your kewtech light mates and socket adaptor? That's all mine does.
No, it performs a very important job during the summer months as a door stop for the back door so's I can get fresh air into the kitchen.
I know that ideally I should have an extractor fan thngy but don't know what size to get or how to wire it.
I'd recommend kewtech jump leads.
Simply to croc crips with about 3" on cable between them. Makes linking cables for r1+r2 easy and link earth bar to busbar for radials.
True, time is money though lol but yes making your own would be a cheaper option...
On that note I've just been shown adaptors to change from Es/bc/gu10 etc... Couple of quid each to on theory you only need one light mate
Light mates come as a set so you get them all at once, plus adding extra connections in to test leads is a bad idea as it introduces more resistance
Mike Blair,
shanky887614,
